dump valve on 1999 a4 1.8TQS (180bhp)
Bradderz_1988 Aug 20, 2010
  1. Bradderz_1988
    3,947
    235
    any1 got any pics off there dump valve on there car so i can see how to mount mine when i purchase it in next few weeks ??
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    why do you want a dump valve?
    the car is set up to recirc the vented charge back into the TIP. if you dump it you may through some codes, you will certainly end up running a bit rich and you could end up with worse performance.
    much better getting a decent recirc valve.
    If it the noise you are after just get a sheilded cone instead of the airbox
  3. Bradderz_1988
    3,947
    235
    How do I go about the sensor on top of air box when fitting a cone ?? Was looking at getting the splitter from forge ?? Any easy to mount ??
  4. Oranoco
    Oranoco Well-Known Member
    3,870
    381
    That's just the ignition amplifier. I just zip tied mine out of harms way. Never had a problem with it.
  5. Bradderz_1988
    3,947
    235
    Cheers will do !!
