dump valve. i need a new one.
chrisa4quat Aug 10, 2011
  1. chrisa4quat
    chrisa4quat Active Member
    970
    as i am in process of remap etc i'm going to upgrade to a forge one i think. i just dont know if to go for a recirc or an atmospheric. do the atmospheric valves cause any loss in power etc?
  2. hades-
    9,481
    646
    the forge is full recirc
    for a blow off you need the forge spacer
    no power loss on mine and i run the spacer aswell
  3. Triple.O.G
    Triple.O.G Active Member
    1,113
    Go for a recirc mate, a recirc will recirculate the excess boost back into the turbo system where as an atmospheric one will just dump it into the air, you might notice a slight dip in mpg if you fit an atmospheric as your turbo has to create all the boost required from scratch everytime you lift on.
    Atmospheric ones sound pretty sweet though, it depends what you want from your car?
  4. Marrow
    Marrow Member
    587
    I have had both didnt notice any difference in performance or mpg just the noise. Revised OEM is good plus its cheaper and easier to fit than the forge.
  5. Triple.O.G
    1,113
    Im speaking purely from a Subaru point of view which is the same in theory but obviously all engines are different.
    I probably should of mentioned that before :)
  6. hades-
    9,481
    646
  7. hades-
    9,481
    646
    the forge does recirc even with the spacer fitted so it dont dump all the boost
  8. audicruiser
    audicruiser Audi Heaven
    1,865
    Don't bother with atmospheric as they can cause problems with unmetered air and cause running problems. Your just a well getting the Rev D valve from Audi for just under £50. I am running that on my A3 with no problems....
