Dual Temperature Sensor help
bigslippy Jul 21, 2012
  1. bigslippy
    bigslippy New Member
    27
    10
    Hi guys , I have a 2003 A4 1.9 tdi quattro, temp gauge hasn't worked for a couple of years and I had heard that if the temp
    sensor isn't working , the ECU still thinks the engine is running cold and uses more fuel?
    Is this the case as round town driving I get mid to high 30's , when I go on a journey I get mid 40's.... I wouldve thought 50+ would be easily achievable.
    However , I've now discovered the part I need is called a dual temp sender .... does mean that 1 part tells the temp gauge what the temp is and the other part tells the ECU?
    Hope this makes sense to somebody[​IMG]
    Any thoughts/wisdom welcomed[​IMG]
  2. marktdisport
    marktdisport Active Member
    1,195
    15
    To be honest after a few people on here with 1.9 Q say they only get mid 30's and there's a few fwd only doing mid to high 30's.. My fwd comes in as average around 42-45 mpg but if I do 550 miles then 400-410 will be dual Carriageway to work @ around 65-70 mph...on a very long journey it will creap to a near 50 driven carefully.. The temp sensor will work in a few ways but they all do.. Should just be a simple change over
  3. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Just get your temp gauge fixed, usually only the thermostat or coolant temp sensor.
  4. pauldazzle
    pauldazzle Well-Known Member
    1,132
    81
    Temp sensor failure is one of the most common failures on VAG cars.
    Yes the CTS has 2 outputs 1 to the gauge & 1 to the ECU. If the ECU is getting incorrect reading from the CTS it won't fuel correctly. Make sure you get a genuine VAG replacement (£25ish) Aftermarket CTS's are notorious for failing.
