Dual mass or Solid mass flywheel???
S3_chris 11 Sep 9, 2013
  1. S3_chris 11
    S3_chris 11 Member
    188
    Whats the difference or the best for an s3? Someone's told me solid for a stage 1or2+, but many garages have told me because the s3 engine has more torque it will shed the solid one within 500 miles so its best replacing it with what its got.
    Help is appreciated and advice is 100% needed
  2. S3_chris 11
    S3_chris 11 Member
    188
    By solid I mean single mass
  3. <tuffty/>
    20,896
    3,705
    Nowt wrong with dual mass... I run one on mine with a paddle plate and no issues at all... mines a little more than stage 1/2.... lol
    Load of **** about the single mass too... if 500hp + 1.8t's can survive on a SMF then I am sure your remapped K04 can manage
    No such thing as 'whats best' as this is subject to intended use and how you drive plus ultimately power...
    I use a DMF, std clutch pressure cover and Sachs paddle plate... thats with 400hp and 320ftlbs torque... its fine as a daily and won't **** itself if you do the odd launch..
  4. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    I've had my SMF on for over 5000 miles now and the only issue I had was it blew my gearbox up after the first 200 miles as she was clearly very tired! lol
    Replacement gearbox and a new SMF in and no issues what so ever - so clearly it was down to a tired box.
    As per tuffty said - it's all down to how you drive and if you mind a bit of chatter on idle from the SMF....also worth noting that a solid flywheel will never need replacing as apposed to a dual mass flywheel.
  5. S3_chris 11
    S3_chris 11 Member
    188
    Ok so i went with sachs DMF clutch and slave bearing. Its all in bolted back together. Now have a big problem. My clutch pedal is stuck to the floor and wont return. Help needed please guys
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Have you bleeded the clutch?
  7. S3_chris 11
    S3_chris 11 Member
    188
    Tbf didn't know you could bleed the clutch.how do u do that
  8. S3_chris 11
    S3_chris 11 Member
    188
    It's been bled so ive been told but still stays pressed to the floor :s
  9. <tuffty/>
    20,896
    3,705
    Master cylinder is gone then...
  10. S3_chris 11
    S3_chris 11 Member
    188
    Thanks guysa
  11. BigJohn
    BigJohn New Member
    9
    when my clutch went I fitted a single mass, feels so much better glad i done the research and fittied one. Hope that helps :)
  12. Dani_B19
    9,109
    346
    Bigjohn what flywheel and clutch you running?
  13. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,814
    193
    I have 35-40k miles on my helix single mass conversion now, but i cant wait till it slips and i can change back to a duel mass. Town driving is tedious now, and the idling chatter is starting to annoy me!
