Dual mass flywheel
cee-gee Apr 11, 2011
  1. cee-gee
    cee-gee New Member
    Hi All
    I have a 2006 1.8t A4 Cab, 45k on the clock and the clutch/DMF has gone.
    Thinking of converting to single flywheel, has anyone else done this or have any pro's/con's regarding the change.
    Any advise appreciated.
    Craig
  2. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    I had the same issue myself, in the end I just replaced it with a DMF and a clutch. I had it done on tuesday, it drives like a new car now
  3. bdub
    bdub Member
    I would personally replace with a DMF. They are there for a reason and if all that extra vibration ends up in the powertrain it cant be good news!, I cant believe you would save that much money anyway, as most of the cost is labour.
  4. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    im useing a smfw but stage 4
    no problems with it
  5. cee-gee
    cee-gee New Member
    Opted for a like for like change, DMF & clutch. Is now like a new car :)
  6. oldoiler
    oldoiler Member
    47
    Interesting, seeing your comments I always thought that DMF were only fitted to diesels due to the way power is applied and NOT to petrol units!!. A lot of the performance chaps with Seat Leon's have used solid flywheel setups on both petrol and diesel [ BDUB is right, it would verbrate down the transmission line long term though with possible failures. Manufactures are looking to get rid of the DMF due to the failures and go back to solid setup and do the controlling thro the engine ECU, but I'm sure diesels are the main culprit !!
  7. bdub
    bdub Member
    If manufacturers could save money on not fitting DMF's I'm sure they would, even a £10 saving on unit cost would equate to Millions on bottom line profit. I could be wrong but strongly think they are there for a reason.
