Dual mass flywheel conversion
Discussion in 'A4/S4 forum(B5 Chassis)' started by Bradderz_1988, Apr 1, 2011.
  1. aragorn
    aragorn "Stick a V8 in it!"
    Staff Member Moderator VCDS Map User
    Jan 30, 2008
    17,104
    554
    The problem with the DMF is that its not flat, the clutch sits down in a dip, so fitting a larger one isnt really possible.
  2. Advert Guest Advertisement
  3. AR-rkon
    AR-rkon Mod back in a "B"
    Staff Member Moderator Regional Rep Team Silver Audi A4 Audi Avant Owner Group
    Oct 8, 2010
    1,908
    156
    Would a solid flywheel from a mk3 passat work?
  4. aragorn
    Jan 30, 2008
    17,104
    554
    afaik mk3 passat has a transverse engine like a golf, so no it wont.
  5. AR-rkon
    Oct 8, 2010
    1,908
    156
    WIN!!! got a flywheel from a 1Z audi 80. £54 inc vat.
    are there an other clutch "kits" that can be utilised? or just the 3B. cant get hold of an LT pressure plate, or an S4 B6 friction plate... :think::crying:
  6. aragorn
    Jan 30, 2008
    17,104
    554
  7. Jason.s
    Jason.s Active Member
    May 12, 2010
    2,879
    348
    Other than the S2 kit and the strange mix aragorn has put together no..
  8. AR-rkon
    Oct 8, 2010
    1,908
    156
    Is it definitely a 2.8 tdi LT clutch plate, found a 240mm one from a 2.5 tdi? Anygood?
  9. aragorn
    Jan 30, 2008
    17,104
    554
    Sachs only links the S2 one against the 2.8TDI.
    The 2.8 and 2.5 are very different engines and the flywheels are completely different.
    The S2 cover is also used on Audi 100 and 200 "2.2 Turbo" models, but i've had a look and the only clutches for those on ebay look a bit ****.
  10. AR-rkon
    Oct 8, 2010
    1,908
    156
    ok. may have found one. from an AGK 2.8 engine. (i presume this is the right one, i think i saw that code on the sachs catalogue).
    probably a daft question but does the orientation of the pressure plate in relation to the SMF have a specific, or can it be put on in any orientation?
  11. aragorn
    Jan 30, 2008
    17,104
    554
    You got a link to the one you've found? Or a part number?
    Dont think it matters, the locating dowels are equi-spaced round the circumference.
  12. AR-rkon
    Oct 8, 2010
    1,908
    156
    you have PM (stops anyone browsing the site, robbing it before i can get it)
  13. aragorn
    Jan 30, 2008
    17,104
    554
    replied.
  14. AR-rkon
    Oct 8, 2010
    1,908
    156
    I've found out from the seller I can get just the pressure plate from him for £30 (if it will work?), then all I need is the V8 disk and a release bearing (from/for what?)
    Aragorn/Jason can you advise?
  15. aragorn
    Jan 30, 2008
    17,104
    554
    Release bearing is just a standard A4 one.
    The clutch you found appears correct, in sofar as the engine code is right. It doesnt look the same as mine though.
  16. AR-rkon
    Oct 8, 2010
    1,908
    156
    what is the edge to edge diameter of your 1Z flywheel? (across the friction side), mine looks too small to take a 240 plate :think: could be wrong....
  17. aragorn
    Jan 30, 2008
    17,104
    554
    The cover plate hangs off the edge by a few mm's, and the bolts are really close to the edge.
    I can measure it if you want though.
  18. AR-rkon
    Oct 8, 2010
    1,908
    156
    yeah if you could :salute: Thanks
    does the "overhang" need to be trimmed back to the edge of the , or will it not foul anything and can be left as is?
    Also, just found an S4 (BBK engine) 4 paddle clutch too :eyebrows: or would that be too brutal/not work :whistle2:
    #57 AR-rkon, Jun 22, 2011
  19. AR-rkon
    Oct 8, 2010
    1,908
    156
    Any advice before i buy it or the standard disk?
  20. aragorn
    Jan 30, 2008
    17,104
    554
    Flywheel measures 277mm and the pressure plate outer edge is 280mm
    No idea if it needs trimmed though.
    Forget paddles, they'll just chew the flywheel and coverplate to bits
  21. AR-rkon
    Oct 8, 2010
    1,908
    156
    Great, Cheers aragorn. sound the same as i measured last night. Ok will give the paddle a miss then :blush:
    Is the MB engine the "same" as the 3B?
    EDIT: Answered own question. MB same as 1B 2.2T (87-89)
    #60 AR-rkon, Jun 23, 2011
  22. Advert Guest Advertisement
    to hide this advert.
  23. AR-rkon
    Oct 8, 2010
    1,908
    156
    Right, Update time.
    Cannot get a 3B kit or even LT van pressure plate. So it seems that idea is well out of the window, as i need one by tuesday at the latest to get it machined ready for next weekend (Fitting Time)
    Seems my only option is the 1Z clutch kit and hope its up to the job... :( Bugger...
  24. sam80quattro
    sam80quattro Member
    Dec 12, 2006
    137
    seen as though my standard 1.8t clutch cant take a bar of boost from the t28 ive decided to change to single mass fly whilst im on, i have a vr6 paddle clutch that i am going to use (providing it has same size splines) its 228mm, does that mean i can just get a 1z flywheel and use the vr clutch, 1z pressure plate and release bearing and it will bolt in and work??? :D
  25. Jason.s
    May 12, 2010
    2,879
    348
    VR6 clutch wont fit as its from a transverse engine..
  26. sam80quattro
    sam80quattro Member
    Dec 12, 2006
    137
    its just the friction plate im talking about.. are the splines different between transverse and longitudinal?
  27. aragorn
    Jan 30, 2008
    17,104
    554
    yes
  28. sam80quattro
    sam80quattro Member
    Dec 12, 2006
    137
    oh bugger lol well the clutch seems ok again now, hopefully it was just oil from the rear crank seal leaking onto it, it was nearly new to look at.. what sorta torque/bhp does the standard clutch give in?
  29. Bradderz_1988
    Aug 19, 2010
    3,679
    184
    The friction plate for the A4 should have 23 splines for the input shaft iirc remember reading it somewhere.
