Dual Climate Control
Boydie Mar 7, 2007
  1. Boydie
    Boydie Guest
    Right im in work and cant be assed going to the car so going to ask you lot
    the other week i did something funny with the climate control
    twiddled the knobs a bit and i found that both sides would be the same temperature if only using the drivers side knob
    my neighbour turned his side up cos he couldnt hack the 16 degree heat and now my settings are messed up
    how do i do what i did before?? lol
    i mean, how do i set the climate control so i can adjust both sides with just the drivers side knob?
    thanks :thumbsup:
  2. Dandle
    Dandle Member
    852
    You need to hold the auto button for about 10 seconds or so and it will sync both sides to the drivers control.
    K88kGM likes this.
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
  4. MarcQuinlivan
    2,539
    9
  5. Boydie
    Boydie Guest
    haha he apologised after!
    thanks guys - ill try it on the way home!
  6. JamS3
    JamS3 Active Member
    2,258
    24
    Does this function stay on even when turning the ignition off?
    If so I take it its just the same to return it to independant controls?
  7. dm_irish
    dm_irish Member
    99
    as soon as the passenger uses the passenger control it returns to independent operation..
  8. MarcQuinlivan
    2,539
    9
  9. h5djr
    9,459
    1,769
    Are you also aware that different temperatues can be set depending on which remote is used to unlock the car. My wife prefers the car to be a little warmer than me. I usually have the climate control set at 20. If my remote opens the car its set at 20. If my wife's remote is used it sets to 22.
    Today's useful reading - 11.06 Sportback manual p131.
  10. Boydie
    Boydie Guest
    ohhhhhhh very interesting
    im the only one that drives it though but id have it on low all the time anyway!
    good lad :D
  11. MarcQuinlivan
    2,539
    9
  12. JamS3
    JamS3 Active Member
    2,258
    24
    It is the key which stores the settings and transfers them to the car when the ignition is turned on with the key.
  13. ahaydock
    ahaydock Member
    140
    I have to adjust the passengers side to get dual control (after I have held Auto) - is this right? Do you think they can change it via the VAG com?
  14. MarcQuinlivan
    2,539
    9
  15. h5djr
    9,459
    1,769
    Having just re-read the item in the Manual, your right. It responds to the key rather than the remote.
    On mine, if I press and hold the Auto button it changes the passenger side setting to match the drivers side setting.
  16. Vertigo1
    Vertigo1 Well-Known Member Team Navarra Audi S3
    3,780
    854
    If you mean what I think you mean, i.e. after pressing auto to sync the two, the left control changes both and the right control "de-syncs" them again, then it sounds like yours is coded for a LHD car somehow.
  17. ahaydock
    ahaydock Member
    140
    Thats right, it works the opposite way around - the stealers have my car at the mo so I have asked them, but they didnt know if this was a coding thing.
    Can anyone confirm whether this is a coding thing? TIA.
