TLDR: Installed both boxes, remarkable transformation , quicker off the mark and power throughout the rev range and very easy install overall. Short term only so will update in future for long term effects of both boxes.
Car spec: A6 C7 Saloon 2.0TDI 177Ps Fwd
Bigger review and install process:
So I have installed the tuning box and pedal box combo today and going through the fun yet anxious process of setting up the tuning box.
I installed the tuning box first then the pedal box so that i could troubleshoot if anything went wrong on either side.
So, once i installed tuning box they recommend you phone DTUK up for advice, in which case I did, the adviser on their end said to go through programs 1-2-3 and then add power to each one from +1+2+3 and for economy it would be vice versa -1-2-3.
Each program could be considered a different style of driving or even a different delivery method so to say. IMO Map 1 is more probably the most aggressive from low to high rpms with Map 3 being more aggressive on a higher rev band and map 2 a more lower RPM power and linear progression. I added power to each one progressively and Map 1 and Map 3 only got to "+2" as the "+3" would go into limp mode when on redline where as map 2 went to "+3" with no problems at all. I went with Map 2 +3 brilliant power delivery and smooth revs and nothing too ridiculous. I want to keep the car running for a couple of years haha
after I did a thorough test of Map 2 +3 for a good 30 minute drive everything seemed to be good so I went on to setting up the Pedal box sent to me.
I have a hanging accelerator pedal so the install was slightly trickier. i didn't exactly remove the plastic cowl/undercover for the steering wheel i just undid the 2x 8mm Torx screws on either side to loosen up the plastic so I could reach my hand through. The plugs were very difficult to plug in, in the sense they needed a lot of persuasion to fit and "click" into place. But once it was completed I went onto playing with the setting and the Manual provided tells you that there is 3 programs to choose from. City Mode(green LED), Sport Mode (Amber LED) and finally Sport Plus (Red LED) or OFF. Again you can choose between how much throttle response you get via a "+" and a "-" which offers three settings with a combination of three green LEDs being lighten up as the more Green lights are on the more sensitive and aggressive the throttle response is. I found that Sport mode with 2 of the green LEDs on is the best for me and sport plus is far too aggressive. They give you alcohol wipes and sticky back velcro for the control switch to be mounted on the car which is a nice touch too.
Overall I am very happy with the purchase. I did all setting on Dynamic so that i know even on the highest setting on my car, the car wont go limp on me haha!
SO LET THE FUN BEGIN
I will update around 6 months down the road to show a longer usage and finally a year in time update
Thanks for reading and let me know your experiences too whether Remap or tuning box
