DTM register / owners thread
olethalb Feb 18, 2013
  1. olethalb
    olethalb Active Member
    357
    77
  2. MiniMrMan
    MiniMrMan New Member
    Hi, Im a new DTM owner, love it.. Standard at the mo /\ Like the sound of this though! /\
  3. olethalb
    357
    77
    get some pics up bud
  4. Olly P
    Olly P My other cars a mk2 Golf GTi
    702
    13
    Well, sad times, i've decided to sell my DTM. Its been fun but need a diesel from my commute to work :bye:
    What do you think of the for sale add? Its been a while since I sold a car and had to write a for sale add!
    For sale add:
    Classifieds: Audi A4 DTM
    AudiSRS.com :: Audi A4 DTM
  5. craichouse
    craichouse Member
    99
    10
    i understand dude, the only reason i own a DTM is i did it the other way around :)
    but you should make membership of this thread and a term of the sale :salute:
  6. Hedski
    Hedski Member
    123
    My DTM has developed an annoying clunk when turning right at low speeds like roundabouts when winding lock on to the right. Any opinions? Doesn't happen when manoeuvring slowly for parking etc. Just 2nd or 3rd gear speeds and it's a single clunk that can just about be felt through the steering wheel. Thoughts please.
  7. DTM_T4
    DTM_T4 New Member
    29
  8. Giosabcsl
    Giosabcsl Active Member Audi A4 saloon
    853
    156
    43
    Were abouts are you based for a start?
    Secondly personally I would not bother going with superchips not that I have anything against them there is just better out there. If you looking for a plug and play route rather look at Revo or APR.
    Also I would not bother too much about the HP gain as its the torque figure that matters. Which superchips torque gain is not the best either considering they state 27nm which is nothing. For £400
    A default generic stage 1 map you looking at least 30HP gain and 70-90nm(55-65lbft)
    As example based on the 2 referenced chip suppliers above there is there "quoted figures"
    Revo - 220hp => 255hp , 221lbft => 287lbft (300nm => 389nm) = £500
    APR 95 octane - 220hp => 232hp , 221lbft => 273lbft = £598.80
    APR 98 octane - 220hp => 241hp , 221lbft => 292lbft = £598.80
    Even thou they are expensive you getting one of the best generic tuners maps on your vehicle.
    My personal advice would be if you can afford to folk out the 400-500 anyway for a chip. Get a tuner to install a custom map for you car as then it can be suited to your needs.
    But one thing I must stress is try make sure your car is running 105% before you decide to chip the vehicle. The experience with the chip is a lot more enjoyable and really makes the car come alive. But with that puts stress on other components so stuff like good and frequent oil changes, cam follower inspected and changed if necessary. And that your timing belt has been changed.
    Otherwise once its chiped there is no going back :)
    Hope the above helps
  9. Giosabcsl
    853
    156
    43
    This has come up a few times. As mine has the same issue thou I get more than just a single clunk :(
    http://www.audi-sport.net/vb/audi-s...-3-0tdi-quattro-purchased-vibration-rear.html
    I suspect your issue you having is very simliar in the above post. If not just read further into the post and you will see my long essay on what I have done and tried and what is suggested etc.
    Enjoy
  10. Hedski
    Hedski Member
    123
    Thanks for that.
    Front pads pads need replacing soon. Anybody have suggestions for good performance but minimum brake dust? Part numbers would help. Ta
  11. Giosabcsl
    853
    156
    43
    If you want Audi to do the job it will be £139 fixed price for front pads inclusive of labour, vat and 1/2 year warranty.
    Your other option could be something like EBC Redstuff or Yellow stuff
    The redstuff produces the least dust of the 2 products but still offers great braking potential
    Were as yellow stuff is more for the sprinted driving or track driving but can still be used on a road vehicle with no issues.
    Redstuff fronts you looking at around £105.13 for the front set
    Yellow Stuff you looking at around £112.63 again for the front.
    Both prices are inclusive of vat but will require fitting.
    Depends on your budget really and what you are after.
  12. JOHNDTM
    JOHNDTM New Member
    Hi Gents,
    I purchased my DTM about 6 months back, needed a few minor things addressing but have been modding and getting what I can over the last few months,
    spec so far... :-
    green panel air filter
    HPFP autotech
    Forge actuator (modified to fit ko3 for a4)
    forge dump valve
    RS4 fuel pressure reg valve (put on but taken off until I get big turbo as fuel pressure was too high on fuel rail)
    RS4 thrust sensor
    FMIC full kit (ebay order from America)
    decat pipe (from America)
    full stainless exhaust (custom made to match milltek specs)
    H&R 45mm lowering springs.
    H&R anti roll bars front and rear.
    Forge full big brake kit.
    southbend stage 2 clutch and single mass flywheel
    19'' CADES BERN wheels with toyo proxes T1R tyres
    15mm rear and 12mm front wheel spacers
    JBS fitted the clutch and sent the actuator away for modding to forge and remapped it for me.
    Excellent service from them and very experienced with VAGS..
    Just ordered this week and need fitting, front snub mount, full set of poly suspension bushes, rear braided lines, front ultra racing strut brace and decided to go over to the dark side and ordered the AP coilovers...
    Mods to come are larger turbo ( Olethalb ) am thinking of pinching yours, S3 injectors, bigger in tank fuel pump, plugs etc.
    Will run and see what I can get on standard internals then maybe think about pistons, conrods, head work etc..
    THQuattro and DieselJake like this.
  13. olethalb
    357
    77
    Thanks for everyones input and keeping the thread alive
    John - you got a really nice car there with great mods
    hoping to get mine completed over the next week or so
    Well got these couple of weeks ago
    Had the tyres and valves stripped out and took them to my mate who does powdercoating, got them back tonight
    got a few bits to do tomorrow, couple of codes to sort and a new N75 to fit but hope i get time to fit the wheels :)
    as Gio mentioned on my thread, i'm interested in looking at the possibility of getting a plate made similar to the golf anniversary to fit to the car and be numbered based on date of production / registration
  14. JOHNDTM
    JOHNDTM New Member
    Thanx mate, are they rotiform wheels? My mate had a set made fgor his TTRS and was slammed and looked awesome.
    Im trying to get mine complete before the end of the year aswell. Just had my poly bushes, snub mount and braided lines turn up this week, still waiting on my strut brace and coilovers.. I have the H&R springs but love the look of yours and want mine lower so went for the AP's aswell as they look like a decent set.
    Im still up for your grabbing your turbo if its still available, ive just ordered them bits and in the middle of buying another house so a little short each month but will hopefully get the cash asap. It should be more than enough for the increase I need as I have my weekend cars so don't want to go too mad.. pictures attached... 148691_10150335105200223_5137896_n.jpg p 1.jpg
    The Porsche I use regularly and the Ultima is in storage at the moment as the weather is ****..
    Hope you like..
    THQuattro and JudderMan like this.
  15. Hedski
    Hedski Member
    123
    Thanks for the response GIOSA. Current pads not finished so will ponder as the car will be getting sold next year, unfortunately. Not even hit 60k yet....
    Thinking the oil on the K&N may have screwed it and filter been there 3 years. Anybody had experience with ITG or other dry filters? Any part numbers useful as always.
    How easy is to replace the potential leaky or cracked valve if that's the culprit as opposed to the air filter causing the drop in power I mentioned before.
    Also is there a paint code for the textured black on the rear diffuser or is it just a typical halfrauds effort?
    Ta
  16. Luki18T
    Luki18T New Member
    Any one knows that car. 135000mile is it not to scary millage?
  17. DTM 88N
    DTM 88N New Member
    22
    Hi GuysNew member here and i joined specifically for this thread. I have had my DTM for just over a year now and absolutely love it!I have no mods on it yet but was looking to get some advice from you guys first. the mileage is currently around 85,000 - would it be ok to start modding this car now? Is there anything i should check out on the car before i start? its had a full audi service history and cambelt changed at 76,000.I really want to mod it bit by bit and increase it to 300+ bhp. but looking to start off with a stage 1 remap and a CAI + dump valve (mainly for the noise :) )I havent figured out how to upload pics yet but the cars in sprint blue!Would be good to do a meet with the DTM owners on here.Cheers
  18. DTM 88N
    DTM 88N New Member
    22
    hi mate, i had the same issue last year. does your car rev up by itself to round x1000 - x2000 revs when idle as well? i got a new pcv valve from audi, only around 30 quid and was able to replace the old 1 in half an hour.
  19. olethalb
    357
    77
    glad to see the thread is still alive with new members posting :)
    DTM 88N - i'd check your cam follower and revision of DV but other than that i can't see any issue going 300+ on your motor
    for all those on k03 turbos (the majority) i strongly suggest you get in contact with Dan at Beach Buggy Turbos and talk to him about his new bolt on k03 hybrid that with supporting mods and decent mapping can crack the 300bhp barrier.
    he is on this forum as well as facebook, just say i sent you to him - I'm sure he'll sort you out with everything you need to know.
    Olly
  20. DTM 88N
    DTM 88N New Member
    22
    thanks olly your like the DTM yoda :)
    some a**hole scuffed the whole left side of my rear bumper the other day and drove off before i could get his reg details!! now i need to get the body work resprayed so the modding is going to be delayed a bit :( just what i needed this xmas!!!
    but thanks for the tips I'll get in touch with Dan in the new year.
  21. ajax1976
    ajax1976 Well-Known Member
    1,281
    662
    olethalb likes this.
  22. olethalb
    357
    77
    Thanks to the mods / admin for making this thread a sticky :icon_thumright:
    Olly
    craichouse likes this.
  23. OxfordRich
    OxfordRich Collecting Rings VCDS Map User
    112
    9
    Anybody fitted cruise control to their DTM and kept the original Alcantara steering wheel (which has no buttons etc)? What was needed.. extra wires, Modules, etc?
  24. JudderMan
    JudderMan Well-Known Member
    1,033
    174
    Ah man, I want a DTM now. If anyone's selling at the end of the year, gimme a shout please
  25. Giosabcsl
    853
    156
    43
    Yes you can keep the Alcantara steering wheel. As the cruise control is a stalk and has nothing really to do with the steering wheel.
    You just need a lower cowl or cut yours the cruise control stalk and someone with a VCDS to install/programme it for you.
    Use this for as a guide - http://www.audi-sport.net/vb/audi-s...191791-cruise-control-installation-guide.html
    Mine will most likely be up for sale end of the year as I will hopefully be getting my S3 saloon :happy:
  26. Hedski
    Hedski Member
    123
    Same here, about to get REVO'd but will be up for grabs at some point in the year. I'll advertise here first.
  27. Tenny
    Tenny New Member
    Hi, I have owned my DTM since October 13...Love it so far.
  28. olethalb
    357
    77
    looks clean Tenny, any modifications?
  29. Tenny
    Tenny New Member
    Yeah Thx mate, no mods as yet...Although I have been looking into an exhaust upgrade, but the only one I can find is the Miltek system. I have heard what it sounds like...and to be honest it is a bit ****. I am thinking I will get a custom one made for it with two twin pipes..
    Need to put induction kit on it, re-map & maybe a dump valve
  30. Tenny
    Tenny New Member
    Hi (A4Chad) the price sounds about right, the main thing which is common is the Coil packs on these. Also, find out when the timing belts were changed, if at all.
  31. Giosabcsl
    853
    156
    43
    The coil packs were offered free from audi under a recall. So if yours wasnt done or if you want to check just ring audi with the vin number and they will share the info with you.
  32. olethalb
    357
    77
    i've listed my 3" decat and milltek downpipe on ebay, i'm not looking for as much as it's advertised for but due to ebay / paypal fees it's bumped the price up.
    contact me direct for better deal :)
  33. Hedski
    Hedski Member
    123
    Well thanks to those on here who recommended changing my DV for the newer type. It's like a new car, I must have been down 100PS by the difference in acceleration and torque. To be fair a diesel Tiguan was able to out accelerate me off the lights. Got car Terracleaned straight after so all sweet now. Vroom.......
  34. DTM 88N
    DTM 88N New Member
    22
    Hedski where did you get your DV from? Think i should change mine if its making that big of a difference. Cheers
  35. Hedski
    Hedski Member
    123
    Ebay. There's a seller on there who sells the genuine article and has several left.
    My clunk turns out to be an engine mount leaking and another perished. Where's best to get them as Audi want a total of over £300 for them........
  36. DTM 88N
    DTM 88N New Member
    22
    nice one mate, which one we looking at though, theres loads on ebay but not sure which one is best? just want to make sure i dont order the wrong one!
  37. Giosabcsl
    853
    156
    43
    06H145710D is the one you want. Ring audi you might find it might be cheaper than some ebay sellers.
  38. DTM 88N
    DTM 88N New Member
    22
    excellent, found it Giosabcsl cheers for that
  39. lukas883
    lukas883 New Member
    9
    Wanted A4 DTM, i need to buy something in next week so if any of You guys was thinking about selling one of this please let me know.
    Millage below 70k, must have BOSE and genuine service history.
    Lukas
  40. Olly P
    702
    13
    Over 70k but full service history, VGC. I've found a replacement and could do with selling asap. Open to offers:
