DTC Fault codes dilemma
S4_dan
Fire up the Quattro!
Somewhere in the Howardian Hills!
Hi, Newly purchased 2.5Q had some DTC's stored. I wasn't sure how long they had been there so I cleared the fault codes last week and gave the car a run for a few days and scanned again. Here is the list:
VCDS-Lite Version: Release 1.2
Wednesday, 09 October 2013, 10:18:01:37918
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine Labels: 059-907-401-AKE.LBL
Controller: 8E0 907 401 D
Component: 2.5L V6 TDI G000SG 0009
Coding: 02015
Shop #: WSC 63351
VCID: 263FE185D1FF
00005059 130 106LC150_1.V79450931286
4 Faults Found:
17978 - Engine Start Blocked by Immobilizer this is a new code
P1570 - 35-00 - -
P1570 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller this code was present before
P1649 - 35-00 - -
18062 - Please check DTC Memory of Instrument Cluster this code was present before
P1654 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04455
Shop #: WSC 00011
VCID: 263FE185D1FF
1 Fault Found:
65535 - Internal Control Module Memory Error this code was present before
00-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
VCID: 2A2715B5C5E7
1 Fault Found:
01809 - Actuating Motor for Temperature Flap; Left (V158) this is a new code
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
VCID: 341B0BCD1723
1 Fault Found:
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent this code was present before
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 950 JX
Component: KOMBI+WEGFAHRS. RB4 D38
Coding: 01400
Shop #: WSC 00001
VCID: 88630F3DBB2B
WAUZZZ8E83A1***** AUZ6Z0B01*****
2 Faults Found:
01176 - Key
07-10 - Signal too Low - Intermittent
01316 - ABS Control Module
49-10 - No Communications - Intermittent this is a new code
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1110
Coding: 07115
Shop #: WSC 63351
VCID: 7399C8D152AD
3 Faults Found:
01134 - Alarm Horn (H12) this is a new code
29-00 - Short to Ground
01370 - Alarm triggered by Interior Monitoring this is a new code
35-00 - -
00962 - Alarm via. Tilt Sensor this is a new code
35-00 - -
End --------------------------------------------------------------------------------------------------
The alarm codes I am not phased by, I will be doing a siren battery repair on mine and my dad's S8 soon.
However, worryingly, some DTC's have returned that were there before I cleared them, all relating to the ABS module. Assuming this is duff ABS and needs replacing? Although, I have no MIL or ABS/TC dash lights on??
Some new codes had arrived too. Just my luck.
HOWEVER, under the drivers floor mat......the carpet is WET!!! So where would be the first place to look? I can't do anything until the weekend, when I will be doing a Mr Muscle job on the turbo anyway.
Any pointers on the above would be greatly appreciated. (I've taken on-board about comments in other post too)
Cheers,
Dan
Check the ECU seal around the ECU box if the carpet is wet on the drivers side.
As above but also remove all the relays, etc in the ECU box to check for corrosion as you have the classic water ingress faults ie comms lost
i agree i took 10 litres of water out of mine , the seat will have to come out , trims off and pull the carpet up to get wet vac in and then foot heater. fix seal first mine had fell into the car for some reason
S
939
4K
