DSG Questions
DaveA3-TDI Apr 15, 2011
  1. DaveA3-TDI
    DaveA3-TDI Member
    249
    Hello.
    I was going to get the oil and filter changed in my 6 speed dsg box and have read that a pipe or tube needs to be replaced at the same time, where is this little pipe or tube located?
    I have also read that the 6 speed dsg is a wet clutch setup, does this mean that the clutch plates are submerged in oil? (not a mechanic lol)
    Thanks in advance
  2. Minstadave
    Minstadave Member
    560
    19
    No pipe to be replaced, you do need a weird pipe to get the oil into the box but you don't have to worry about that if you're not doing it.
    The 6 speed DSG has a wet clutch, so they're submerged.
    Here's the oil change process:
    http://forums.tdiclub.com/showthread.php?t=169356
  3. DaveA3-TDI
    DaveA3-TDI Member
    249
    Thanks, I don't think I will do it myself then lol. Why did they choose a wet clutch, is that better than dry?
  4. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Make sure that the filter is changed as there have been cases where that hasn't been done, the tube you are refering to is the special VAG tool used to fill it with the new oil - VAS 6262 A-
    Paul
  5. DaveA3-TDI
    DaveA3-TDI Member
    249
    Ok, I guess the easiest way to make sure the filter has been changed is to mark the position of the filter housing before it goes in? I could also clean around the filter housing as they will probably spill some oil when they change the filter so I should be able to see the spillage if they change it and none if they don't?
  6. Gti Jazz Blue
    1,655
    That or ask them to leave the old one in the boot in a plastic bag.
    Paul
  7. DaveA3-TDI
    DaveA3-TDI Member
    249
    I wonder if they would really do that lol
  8. Minstadave
    Minstadave Member
    560
    19
    They should do, it's your filter even if you pay them to put a fresh one in.
    It's not a problem of the dealers not changing it when you pay them to do it. It's the fact that you take it in for a DSG oilchange/service and they just change the oil and leave it at that (happened to me last year).
  9. DaveA3-TDI
    DaveA3-TDI Member
    249
    What are they suppose to do service wise?
  10. Minstadave
    Minstadave Member
    560
    19
    Filter and oil change every 40k.
  11. paddy
    paddy Audi=we just sell em mate, we can't fix em.. Team Ibis Audi S3 Black Edition DSG
    5,402
    225
    You need a special tool to remove the drain plug from a DSG box. No point in changing the oil without the filter. In my opinion a wet clutch gives a smoother take up, last longer and does not over heat. It enables the clutch to be smaller for a given power transfer as well.
  12. DaveA3-TDI
    DaveA3-TDI Member
    249
    Still trying to get used to the dsg box but getting their slowly lol. Is it best to let the car change down gears when in tiptronic mode or should you do it yourself. Also will the kick down function work in tiptronic mode or is that just for auto mode?
    thanks
