dsg oil change
jondsg
hi guys
my car is due an dsg oil change, iv bought the oil and filter myself.
question is, do i take it to an audi spesh? or trust my local garage?
im so undecided....
cheers
VAG indy or audi themselves, certain procedures have to be adhered to & it must be followed, if its not a vag specialist they may miss a thing or 2 & its important its done properly for these gearboxes.
cheers mate, the audi specialist is quoting 100£ with me supplying the oil...
Thats a fair price as they have to make sure its upto temp, remove old, fit new filter, put new in, 6 litres if not removing mechatronics unit, then get upto temp then calibrate box & then defined test drive in various speeds.
Cheers sounds complicated, does it matter whether the mech unit gets removed or not? Does this ever get serviced?
Mech unit only gets removed if its got a fault or box is faulty, so 6 litres is normal dsg service, if it is removed its 7 litres to refill.
Not quite right. For a re-fill only 4.5 ~ 5 litres required. For re-fill after mecs unit opened then it's 7 litres.
I've done a few changes myself. Quite straight forward, but needs doing properly.
Some drain the oil, measure the volume, then put the same amount back through the oil filter.
Others use the proper fill point and if they have not got vcds, use an infrared thermometer to check the oil temp in the dsg oil pan.
At most 45min job.
Strange, as had mine done twice by master tech friend at audi whilst next to him & both times used up best part of 6 litres without any loss.
Problem is, if we said 5-5.5 people would be asking can I get away with 5 & then when someone says yes & they are short of some, they would be ****** at us, the actual requirement according to my audi guys is 6 litres, which is why its generally sold in 6 litre boxes & both times mine has arrived specifically in a box for only 6 litres, so stands to reason.
So we'll have to agree to disagree as such based on personal experiences mate :)
881
I
13
5K
