DSG oil change when replacing flywheel?
rickyquicky Nov 25, 2010
  1. rickyquicky
    rickyquicky Member
    342
    My cars due its DSG oil change very soon, but its looking increasingly likely that my car needs a new DMF.
    Question is, is it worth getting my oil changed now and sorting the DMF out later?
    Or when the DMF is changed on a DSG-equipped car do you need an oil change anyway?
    :icon_thumright:
  2. RS84
    RS84 R15 - TDI Power
    168
    Personally I'd keep the money for the DMF, as that's likely to cost a fortune!
    Out of interest, have you gotten any prices on it?
  3. rickyquicky
    rickyquicky Member
    342
    Well the oil change needs doing...just dont want to do it if the mechanic has to drain/refill the oil when they do flywheel change.
    Ive seen eurocarparts have a DMF for about £330 not sure if that fits DSG cars though, and if you set up a trade account with them you might get a bit more off too...I know a transmissions specialist in Kent called 'star transmissions' who will do the labour as well, just a bit worried how much experience he has with DSG boxes.
    Anyone know how much harder the DSG box is to remove compared to a manual a3?
  4. akash_sky1
    akash_sky1 Active Member
    1,181
    Not heard of many DSG flywheels needing replacing, what mods you running?
  5. rickyquicky
    rickyquicky Member
    342
    Well im not 100% sure the flywheel needs replacing...
    When the car is cold and is idling in neutral there is a 'clattering' sound that goes when i put it in 'D' at idle. When im going between 'N' and 'D' the noise comes and goes but I cant see it being anything other than the flywheel. It seems to get better or go when warm though - does that sound like a symptom of failing flywheel?
    Only mods I have are an AMD remap and pipercross panel filter
