DSG can't stall can it??
stewarta13wsb Mar 22, 2007
  1. stewarta13wsb
    stewarta13wsb Member
    139
    I'm on my second A3 with DSG. I've had this one since November and it's only got just under 3000 miles on it.
    When I reverse out in the morning (I'm on the flat by the way) I don't usually touch the accelerator, there is enough power to slowly pull out (it's a tight turn) without it.
    I've always done this and it's never been a problem... until now.
    It's as if it wants to stall, there's even the slight lurch you'd get on a manual. Obviously it doesn't cut out though, it just starts going again.
    Would you say this is normal and it just needs some revs or is something not quite right, or getting worse?
  2. Eeef
    Eeef Lord of War
    1,607
    mine did it a couple of times but my drive is uphill. It would lurch and auto declutch trying to catch the revs.
  3. marriedblonde
    marriedblonde Active Member
    4,373
    9
    mine did it a couple of times but only on an incline. does it do this all the time?
  4. stewarta13wsb
    139
    Once, then a gap of a couple of days, then the last 3 times I've reversed out (unless I give it a little throttle) :think:
  5. newbiecrg
    newbiecrg windsurfer
    1,328
    Does the car idle normally?
    I'm not familiar with DSG but have used automatics before and did the same as you, backwards without pressing the accelerator...
    Pedro
  6. OutLore
    OutLore VOIP Dude
    1,206
    Mine stalled a couple of times, but only ever first thing in the morning, reversing on a hard right hand lock... no throttle - almost as though there was not enough power to keep going or something
  7. DSGSport
    DSGSport New Member
    23
    Mine has Stalled a couple of times. Once when the car was crawling in traffic coming up to a round-about. The other when reversing (on the flat) off my drive. Audi looked at it but said that nothing was wrong.
  8. Amchlolor
    Amchlolor Active Member
    5,604
    Mine also sometimes stalls when reversing out of my drive in the morning,when I go from reverse to any forward mode.
    It also tends to take an age to go into the forward mode,followed by a helluva lurch,like a learner driver using a manual clutch.
    My drive and road is also on a slight incline.
    Is the 'hill-hold' still an option or standard on DSG these days ?
    One of my routes involves stopping on what must be a 1/5 incline.
    It's laughable,it's worth filming.
    You either have to put the handbrake on,resulting in the car groaning against the back brakes,or you try and hold it on the throttle resulting in you rolling backwards and forwards in a daft manner.
    I often then get the same symptoms as when I pull out of my drive.
    I press the throttle,revs rise,nothing happens,BANG you're off !
  9. stewarta13wsb
    139
    Yes, idle is fine.
    Sounds like it could just be the colder, damp weather? It's no hardship to touch the accelerator, just that I didn't have to before.
    Bowfer....:) I knew you'd be in there when it was a DSG thread :respekt:
    Thanks all,
  10. Skittler
    Skittler Redlined
    136
    Bowfer,
    I'm not being flippant here as you have some genuine issues with the DSG, some of which I even agree with when you're in rational (not ranting) mode :)
    I can certainly see things from your point of view and I think over many threads it's a love it or hate it thing, but...
    If it's really that annoying, why not just sell it?
  11. SamDude
    SamDude Active Member
    2,102
    Cos its a company car....
  12. stewarta13wsb
    139
    :ohmy: ... didn't mean to start anything there - I for one love Bowfer's posts. There's always serious knowledge or info (or both) mixed in with a laugh, and God knows I need a laugh now and again :jump:
  13. Skittler
    Skittler Redlined
    136
    Me too. This board just wouldn't be the same without Bowfer.
    Quieter maybe...but just not as good :)
