DS 2500 arrive today...
Nitro Mar 12, 2010
  1. Nitro
    Nitro Member
    183
    My new pads arrive today via Fedex, anyone got any tips I should know or do when fitting these to standard disks and calipers?
  2. Matt82
    Matt82 Active Member
    2,365
    make sure you clean and grease up the slider pins
    otherwise its just like fitting any other pads
  3. Nitro
    Nitro Member
    183
    Thanks Matt, when you say grease up the slider pins is that with Copper Slip or should I use another type
  4. Matt82
    2,365
    normal grease. copper slip is abrasive and the caliper moves on the slider pin, i just use normal grease.
    wire brush the slider pins up till they prestine clean.
    other than that, the pads are like any other pads to fit
  5. Nitro
    Nitro Member
    183
    What do you do with the break wear warning cable as the new pads dont have any thing on them
  6. Broken Byzan
    13,237
    465
    pull the wires off the old pads, strip the ends off, crimp/ solder tape/heatshrink and plug back in.
  7. Nitro
    Nitro Member
    183
    if i do the above it will stop the warning light coming on, but wont come on when the new pads wear down, is that correct
  8. OldRedEyes
    OldRedEyes Member
    445
    yes, you are correct
