Droopy Gap
wuta3 Jul 23, 2013
  1. wuta3
    wuta3 Well-Known Member
    1,129
    347
    Hi all,
    searched about couldn't find a solution. Door drop resulting in a gap at the top. Not sure if they are independently adjustable. Also, not sure what caused the wear on the pillar. Any help/ideas on fixing the drop?
    (notice the wear above the door corner and the drop. It doesn't look too bad in the pic but is about 4mm)
    Normal?
  2. BradV6
    BradV6 Member
    84
    hinge or catch alignment? no idea! Mine sits tight tbh.
  3. hades-
    9,481
    646
    door catch can be adjusted
  4. wuta3
    1,129
    347
    So it's the catch not the hinge? Any idea how I adjust?
  5. hades-
    9,481
    646
    it could be the hindge
    look at the catch you will see just loosen the screws and adjust till you get it right
  6. wuta3
    1,129
    347
    Just been outside, can't see any catch adjustment ... do you mean the metal loop bit on the pillar or the catch/lock bit in the door?
  7. hades-
    9,481
    646
    yes sorry on the pillar side
  8. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    It's probably the door dropping on the hinge. It is quite common and there was a thread on it recently.
  9. DarkBunny
    DarkBunny Active Member Team Sprint Audi S3
    497
    112
    43
    I would certainly say door dropping from the hinge aswell - it shouldn't go that low.
    You've not by any chance had someone/something hanging off it while the door was open have you?!
  10. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,450
    588
    Yeah I have this problem too on my passenger side - haven't had an opportunity though to investigate it but my guess it is at the hinge.
  11. wuta3
    1,129
    347
    Na both doors are the same. Not got any worse since I bought it ... just trying to work out how to fix it lol
  12. Jord
    Jord Member
    280
    I've got the same problem, I'm gonna try jacking the door to pop it back, big brutal I know, but few of mk4 golf lads have done the same
  13. OFFSKEE
    OFFSKEE Member
    81
    10
    Not been in a bump in its past life would you know ?
  14. wuta3
    1,129
    347
    Door drop is common, not a reason to suspect a bump. esp when the drop is the same on both sides.
  15. OFFSKEE
    OFFSKEE Member
    81
    10
    Didn't mean to come across negative fella it's just that this is not uncommon with cut and shuts. Hinges can be adjusted by the way but best by removing the door first. Depending how much you need to move each one.
  16. Boydie
    3,450
    588
    Its a common problem across the majority of modern vags - a good mate is a seat mechanic and they get them in quite often but they contract it out elsewhere.
    Jacking it up won't help unless you loosen the door first, jack/lift it up then tighten again.
    OFFSKEE likes this.
  17. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    Just had a look at my Haynes manual - it says you can do limited adjustment on the top hinge.
  18. SL11CKK
    SL11CKK Active Member
    700
    Hows the bottom of the door. Post a pic
  19. SAiLO
    1,075
    62
    My passenger door dropped to the extent that the bottom plastic lip chipped the paint of the car metal chassis.
