Droning noise?
Lee Goodall Feb 22, 2010
  1. Lee Goodall
    Lee Goodall Active Member
    2,279
    Yesterday I noticed an odd droning noise that's only audible around 2000 Revs. If I drive at 2000 revs it is constant but if I accelerate or decelerate it totally stops. Anybody got any ideas?
  2. Lee Goodall
    2,279
    It seems that the noise only occurs in third gear so I'm guessing it's gear related. Hopefully it's nothing to worry about but something I've just not noticed before in the new A4 with the six speed box.
  3. Broken Byzan
    13,237
    465
    Rear diff?
    LMAO !!
  4. aragorn
    18,380
    831
    Some kinda resonant frequency perhaps?
  5. Broken Byzan
    13,237
    465
    TBH it's probably the std low revs V high ratio gearbox and LWFW Lee.
    Gimme a ring if it's troubling you, or hopefully be listening shortly
  6. Lee Goodall
    2,279
    Cheers dudes.
    It's not troubling me but I thought I'd see if anyone else had encountered a similar sound. Realised this morning that IFAIK there isn't anybody on ASN with the same gear setup with an AEB so I guess that's the key!
  7. Lee Goodall
    2,279
    if only!! lol
  8. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    what kind of radio do you have?
    I find moderate volume is the answer to the ever increasing noises my car is producing!
  9. Lee Goodall
    2,279
    My stereo only has two settings.. 'off' and 'loud' so I'd imagine that would be an adequate solution :icon_thumright:
  10. Broken Byzan
    13,237
    465
    She is a one only mate..... I miss her BBOOOOHOOOOOO
  11. Geeman
    Geeman Low Life
    1,318
    Lee, forgive me if I'm a bit slow on the uptake here... but are you running a 6-speed 'box in the B5...?
  12. Broken Byzan
    13,237
    465
    Yep, its a 2wd 01E diesel box. Solid strong and damned good on the motorway.
    I also changed the shafts and CVs to heavier stuff to cope with the extra torque afforded by the Outlaw.
  13. Geeman
    Geeman Low Life
    1,318
    Oooooh... is it a straight bolt-on job, or is there more jiggerpokery involved?
    Is that a B5 model 'box then? I assume it's from the V6 oil burner...
  14. Broken Byzan
    13,237
    465
    needed surgery to the subframe, i had to add the V6 uprights and CVs. 6 Speed gearlinkage. It was from a passat TDi Sport 130 2003. The box itself bolts drirectly up to the engine and uses the 1.8t clutch and slave
  15. Geeman
    Geeman Low Life
    1,318
    V6 uprights... do you mean the front hubs?
    And the V6 CV's...? Inner AND outer, or just outers? Or the complete V6 driveshafts? Is all this necessary with a fairly tame 1.8T though?
    Could the 'box drop in without any changes apart from the subframe massaging?
  16. Lee Goodall
    2,279
    Yeah it does work very well on the motorway. Compared to my old green A4 (5 speed) there is a massive difference in fuel consumption on a long motorway run.
  17. Lee Goodall
    2,279
    All in a day work for Dr Byzanstein!
  18. Geeman
    Geeman Low Life
    1,318
    LOL
    Sorry Lee for hijacking your thread.
  19. Broken Byzan
    13,237
    465
    CVs and uprights were needed to get the correct inners to suit the 'box. As the tripod inners wouldnt mount onto the std 1.8t shafts. If you had a TQS the V6 inners would prob fit the TQS shafts
  20. Lee Goodall
    2,279
    Ha ha no probs mate. I think Mark has a detailed thread from when he put the 6 speed conversion together somewhere on ASN.
  21. jq_quint
    jq_quint Member
    256
    24
    Lee I had a headache also with an annoying drone, but my symptoms were as follows:
    • A god awful drone, that got worse the higher the engine speed...
    • Only appeared on certain journies
    • Got worse on certain times of the month..
    It was only when I got rid of the 'ex' that the noise went away....strange one that ?
  22. Geeman
    Geeman Low Life
    1,318
    LOL - I was originally going to put a sarcastic post about a whine I had, but then thought better of it!
  23. Lee Goodall
    2,279
    LMFAO :icon_thumright:
