Droning noise from front left wheel
chasdrury Jul 5, 2012
  1. chasdrury
    chasdrury Member
    362
    17
    Hi
    My front left wheel makes a droning sound - worsened when going round a roundabout - I presume a wheel bearing is going - the car has done 126,000 and never had them replaced - does that sound like a feasible cause?
    Chas
  2. JtotheD
    JtotheD Active Member
    907
    26
    yes. the wheel bearing going will cause vibration up the shocks and will go up to the top mounts which is why you get the droning noise. gets worse above 40mph?
  3. chasdrury
    chasdrury Member
    362
    17
    It may be a bit worse, i just change down and listen to the Milltek instead! :)
  4. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Get it changed as soon as you can. I was in a friends car that had a failing wheel bearing and the wheel pretty much fell off once it gave up........interesting experience
  5. marktdisport
    marktdisport Active Member
    1,195
    15
    it does sound like your wheel bearing m8 imo!! but check the tyre closely aswell as when i purchased mine the rears sounded like the wheel bearing was well past it but it turned out to be a cheap budget tyre were the inner side wall was badly distorted causing the noise due to the tyre being out of shape...
  6. chasdrury
    chasdrury Member
    362
    17
    THanks - will check the tyres but they are only 5k in Goodyear Eagle F1 assymetrics so shoudn't be that - just passed it's MOT so think they'll be ok!
