Drone, Drone, Drone?
abimogen Feb 23, 2011
  1. abimogen
    abimogen New Member
    10
    Hello all.
    Would I be right in saying a drone round a left hand corner is the driver side bearing? It goes quiet round right handers.
    Also, how easy is it to get the sump off? (1.8 20v n/a) The chain tensioners making unholy row! I want to give it a flush, clear out the oil pick up and replace the leaking sump gasket. Makes sense to do it all at once.
    I know its full of orange plastic bits from the dipstick guide that fell to pieces!
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    sounds like you have a lot to do!!
    bearing noise can be transferred so what sounds left is actually right. but change in tone on cornering is usually a safe bet
    you will need to lift the car/engine up off the subframe slightly to clear the sump
