DRL's fitting into fog light trim
Funky Dunky Jul 15, 2012
  1. Funky Dunky
    Funky Dunky It's all about the Quattro!!
    23
    hello
    just wondering if any one had tried fitting some drl into the area of fog lights on the a4 avant b7 s line
    ive got some seperate led lights which need a 20mm diameter hole for each one.
    any advice would be greatfull
    duncan
  2. carl-1968
    carl-1968 A4 sold, lots of bits available, ask for details
    538
    30
    I brought the set off ebay for £99, saved me loads of hassle and match the honeycomb RS4 grill I have, if you want a pic, pm your email as I still cannot post on here
    Carl
  3. Funky Dunky
    23
    have pm you
    dunc
  4. Richardesty
    Richardesty loves quattro
    742
    20
  5. disco-barry
    disco-barry New Member
    27
    I've just ordered these, they will look great and they aren't diy but you do have to pay for it.
  6. Funky Dunky
    23
    Hello these ones look quite nice.
    are they plug and play??
    could you send me a link to these lights please
    duncan
  7. carl-1968
    538
    30
    Update, after driving thru about 18" of water after the road flooded, the N/S is not working so I think I will have to investigate, hope the unit is fixable
  8. disco-barry
    27
  9. disco-barry
    27
  10. Funky Dunky
    23
  11. carl-1968
    538
    30
    Looks good to me Duncan
  12. guyzza75
    guyzza75 New Member
    17
    I bought a set for my fog light grills off eBay for 30 quid..came with brackets and wiring loom and relay box...I screwed the brackets into the grills and clipped them in..then to find a live feed with ignition only I opened the bonnet and there is a large multi plug on the right had side clipped into a metal bracket..just before the inner wing area ..I unclipped it apart and checked with a multimeter and found a live wire when ignition on..( appears to be from esp system) .then snipped the wire 3 inches back and connector block to get feed. Then run a wire to the battery for permanent feed from battery and wired an earth wire to earth feed centre of bulkhead .. The relay then comes with a bolt hole so undid a bolt at top of radiator to right hand side ( front view)and bolted back in using same bolt.. Took around an hour..and bought coil wrapping to hide wires.they also stay in for 1 minute after switching ign off to light the way... Dam they look good !!! A4 sline b7 2005 2.0 TDI..do so at your own risk it worked for me ..happy to help if anyone wants further info
  13. SDHA4SLine
    SDHA4SLine Well-Known Member Team Silver Audi Avant Owner Group S-line owners group
    2,625
    522
    They may look good but blocking more than half the air flow to your intercoolers isn't something I would ever want to do
  14. guyzza75
    guyzza75 New Member
    17
    They don't feed the intercoolers on mine as the grills have covers on the back of them so the grills must be only for show I'm assuming ??
  15. SDHA4SLine
    2,625
    522
    Fair enough, they do on mine but it depends on spec :grimacing:
    guyzza75 likes this.
