DRL/ Side light Load Resistors
Darren198712 Jan 9, 2013
  1. Darren198712
    Darren198712 Member
    194
    14
    Right I have had a search on a few forums and it is unclear what load resistor is used for what.
    I have only found DRL's but it would be helpful if someone posts up Numberplate lights and front side lights too
    DRL
    led drl bulbs with resistors installed (pics)
    Claims to use 25ohm 25watts on DRL's
    LED DRL's finally
    Claims to use 10ohm 25watts on DRL's
    B7 Audi A4, S4 and RS4 LED Daytime Running Lights (DRL) | Nick's Car Blog
    Claims to use 25ohm 10-15watts on DRL but in the picture he uses 15ohms 25Watts
    How to fit LEDs to the RS4 B7 DRLs
    does not specify
    I was wondering if someone can post up what they have used?
    Darren
  2. Richardesty
    Richardesty loves quattro
    742
    20
    Personally I've used 10w resistors when replacing sidelight bulbs (one per bulb), 25w resistors for DRLs (21w bulbs - one per bulb) - just one of these for a pair of numberplate lamps - and 50w resistors for H11 fogs (one per bulb). All from eBay 'load resistor' search.
    Darren198712 likes this.
  3. Darren198712
    Darren198712 Member
    194
    14
  4. Darren198712
    Darren198712 Member
    194
    14
    bump anyone ?
  5. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Start by assuming that the LEDs take so little current you can ignore them when calculating the resistor value. Then apply theses two formulae:
    Power = Voltage * Current
    Resistance = Voltage / Current
    Which means: Resistance = Voltage * Voltage / Power
    So for the resistor you need to make sure that:
    Resistor Wattage = same Wattage as the original bulb
    Resistor Ohms = 12 * 12 / (Bulb rating in Watts)
