  1. burbank2broward
    burbank2broward Member
    75
    9
    I've search and search and search but I have not been able to find how to disable these stupid lights..... I disabled my DRLS in the "auto" position but when I want to run straight fogs as shown in my pic (the only place I can activate my fogs are in the full light position and the other position indicated in my pic)... I get those stupid cornering lights and drls that come on..... how do I remove these and just run straight fogs? I changed my car to euro spec and then ran the fogs as DRLS but then when I went to put gas at the gas station my gas cap opener didn't work... so I put everything back to how it was.. Also if there is no way in hell to get these stupid things off are these the right bulbs to replace them with??
    NOKYA® Hyper White Bulbs PAIR Single Filament Push and Twist 1156 UNIVERSAL
    pics
  2. burbank2broward
    75
    9
  3. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,822
    10,920
    Maybe try putting a post up in VCDS as well may get some replies in there:) x
  4. audicruiser
    audicruiser Audi Heaven
    1,865
    Being US spec, it's hard to know what you guys have set as standard and what you don't... In the UK the Audi's don't have the cornering light function set although the Golf Mk6 does.
  5. burbank2broward
    75
    9
  6. Artimus
    Artimus Shortback
    2,017
    485
    Shall we assume your 'gas cap opener' is an internal switch? Okay, that being the case, We don't have that in the UK! we just have a push to open\close petrol flap that locks\unlocks with the car's central locking ...so setting your electrics to Euro would disable your petrol flap switch. you'll need to find the code for the switch in VCDS and re-enable it after you've set your Euro preferences.
  7. SootySport
    SootySport Well-Known Member Team Silver
    2,952
    786
    Strange lighting switching in the US, I'm bamboozled.:ohmy:
  8. Ash187
    7,520
    758
    that is the standard left hand drive light switch
    the red ring is on the side lights, the drl is actually brighter than the side lights but is essentially the same bulb.
    unfortunately there isnt a way to disable the bulb.
  9. burbank2broward
    75
    9
  10. burbank2broward
    75
    9
    this is my current switch.....
  11. Ash187
    7,520
    758
    As you can see your DRL and the sidelight switch are separated. As far as i remember it cannot be deactivated but you might be able to use VCDS and code the sidelights brightness down to zero so that it no longer lights up. i dont know how that works with your country laws but that might be the solution you need.
