DRL for your S3 fog grills?
Khufu May 27, 2009
  1. Khufu
    Khufu Well-Known Member
    5,704
    31
  2. HotboxDeluxe
    HotboxDeluxe automatic
    1,134
    :lmfao: not even "finished" flung together either...the seller states they are "almost finished" and still need to be glued together or similar
    :huh:
  3. sleeves_008
    sleeves_008 Member
    Absolutely horrendous! :keule:
  4. Ash B
    Ash B Well-Known Member
    5,831
    84
    A bit too much £££ for me lol and also not finished ha :)
    Ashley
  5. drsilviuro
    drsilviuro Member
    121
  6. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    Here's what I did: (non S-line, Non-S3, regular US-spec A3...)
    Drilled a closely-spaced diagonal set of 5mm holes:
    Same thing, but backlit:
    Made some 0.1" pitch circuit boards to stuff behind there:
    Here's one inserted through the carefully-drilled holes into the fog grille, with the others close by:
    Here's two loaded in, one either side of the center 'rib':
    rear view of the LED clusters wired through current-limiting resistors:
    Test-lit using a DC bench supply:
    Two of them test-lit:
    Lights out... it's pretty damn bright!!!:
    Here's the two foglights side-by-side, unlit:
    ...And I experimented with some film-set lighting gel (www.leefilters.com) to correct the light from "blue-white" to PURE white (seen to the left in this photo:
    ..then of course, I got a bit giddy, and added two half-rows (one above, one below) to each fog grille, with super-bright AMBER LEDs, to use as turn-signal repeaters:
    I've still got to install them, but they shoudl look pretty 'stealth'. -They're actually mainly 'hidden' by the 'ribs' above them, but they should light up pretty well once they're on there.
    Keith
  7. Khufu
    5,704
    31
    jeeze thats a fair amount of drilling! I think a single layer looks ok but aren't you getting carried away?? LOL
  8. VWAddict
    656
    9
    ...I don't know the MEANING of "getting carried away"!!!
    ...no, seriously... my vocabulary is terrible!!! ;)
  9. PregnantNproud
    PregnantNproud Gears of War
    304
    if i am going to put drl's on my a3, theyre gonna be in the lights. Where they belong lol!
