Driving in France/Europe
wilko Jul 15, 2009
  1. wilko
    wilko Top Gear
    725
    Hey guys, I believe there is a way to alter the Zenon headlights to work in Europe (mainly France). Does anyone know how to do this? I was under the impression that there was a lever inside the headlight unit that you moved up (or down) depending on the direction required - but I had a look today and could see of feel any lever. :uhm: Your help would be gratefully recieved it's something that I don't want to have to take the car to the dealer for if it can be helped.
    BTW the car is a 2005 8P should it make any differene.
  2. Xerohour
    Xerohour Active Member
    218
    30
  3. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    66
    Xerohour found this post in the FAQs thread at the top of the page. Have a read of it before posting a question next time please.
  4. renfrew
    renfrew Member
    41
    Good advice, Staz, except that the quoted thread refers to Bi-Xenon headlights. I believe that the standard Xenon headlights do use a lever, but since I've not taken my 05 A3 abroad yet I cannot say with certainty.
  5. Staz
    6,206
    66
    I'm fairly sure that they're the same to be honest. Dave is the expert though!
  6. royjk
    royjk Member
    167
    Think you have to take car into Audi, from what I have been told it is only from the A4 up that you have a lever to adjust the headlights. My local Audi garage have quoted £50, thats both ways. I am driving down to Croatia in Sept so if anybody finds more info I also would be interested
  7. h5djr
    9,438
    1,757
    My item in the FAQs certainly refers to Bi-Xenon headlights on a 2007 A3 and later. I do remember there being a lever to change the headlights on some of my earlier A3s but they all had Halogen headlights rather than Xenons.
    I will have a look in Elsawin and see if it gives any more information.
  8. h5djr
    9,438
    1,757
    I've just looked in Elsawin and it looks like a 2005 8P with Xenons should have a lever in the headlights to change them for continental use. Here is a link to the Elaswin page which may help:
    change xenons for continental use
    If your particular headlights do not have this lever then it may well be a visit to the dealer to have them changed on their diagnostic kit.
  9. Staz
    6,206
    66
    Nice one! You going to add that to your FAQs post?
  10. h5djr
    9,438
    1,757
    Good idea Staz - Done
  11. HotboxDeluxe
    HotboxDeluxe automatic
    1,134
    Thanks Dave :thumbsup: I was wondering about this too, the last 3 times I've been back to the UK in the car I've had loads of people flashing me - my thought process was something like "yes, okay, thankyou for blinding me in return, but I'm not sticking **** on my headlights, and I can't find the little lever, so keep flashing and sod off"
    Will investigate when I get home! Thankyou
  12. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Bit of a PITA to have to take a spanner to disconnect and re-connect the battery though.
    I guess that is corporate Lawyers involvement so that no one electrocutes them selves.
    Anyone doing this must be very, very careful due to the HV used in Xenon lights. You must certainly make sure that the lights are in the off position.
    I'd be tempted to also wear rubber gloves whilst doing it.
    Paul
  13. wilko
    wilko Top Gear
    725
    Thanks Dave R! I was looking for something totally different... think I saw a post from ages ago where the lever was tooked away somewhere... I'll take a look again tomorrow and find out if that works!
    Can anyone also recommend a bulb pack for the 2005 8P? I want to make sure I'm covered for most eventualities for my trip in August.
  14. NHN
    29,392
    1,736
    Commonly known in vagcom for bixenon headlights as Tourist Mode.
    http://wiki.ross-tech.com/index.php/Audi_A3_(8P)_Headlight_Aim_Control_(Xenon_Plus)#Adaptation
    There's also a cool setting for bixenon adaptives for showroom effect so you can test your lights if the left/right is working properly while stationary.
    http://wiki.ross-tech.com/index.php/Audi_A3_(8P)_Headlight_Aim_Control_(Adaptive_Light)#Adaptation
    As Leon rightly says search would have brought up many threads/posts
    TBH the best option is to lower the beam via the top screws remembering how many turns per side, then when back just turn them back up, number of people on AS have done this before & not had issues, saves disconnecting battery & easy as pie.
