Driving In Europe
defsix Dec 28, 2009
  1. defsix
    defsix Member
    181
    Hi all, I'm going driving in europe next year for three weeks. I need to adjst the headlights for driving on the right, I have an A4 B6 Avant with a HID kit, so no manual beam adjustment, so i have a few options, VAGCOM ? Is it possible ? or a garage, what exactly do they do ? do they replace a reflector inside as per piece 11,http://www.vagcat.com/epc/cat/au/A4/2004/249/57/3163120/
    Any other options apart from stickers ?
  2. chrisash32
    chrisash32 Member
    573
    I would be interested to know this too, as i am driving to Germany again this year.... and also going to Austria.
    I have the same setup as the above post :)
    Cheers!
    Chris
  3. h5djr
    9,459
    1,769
    VCDS (Vag.com) will certainly make the necesaary adjustments for continental driving with standard OEM Bi-Xenons. I have done this several times whilst sitting in the Eurotunnel train!
    But I don't think it will be able to do anything with aftermarket HID units as the cars control modules know nothing about the light units.
  4. chrisash32
    chrisash32 Member
    573
    how would it be done normally then? Surly A4's with standard headlights have been taken out of the uk before..
  5. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    There is a small lever inside the headlight next to the projector that can switch the headlights from RHD to LHD beam pattern projections.
    Read this on a forum thread (not sure where??) some time ago - did not believe it at the time until I looked very closely inside a broken headlight unit I had lying around in the garage - yep it's there OK and you can see it flick the light beam collimator (metal filter) to the other side!!
    However - don't think it's the sort of thing that could be tackled with the headlights in place - will require them to be removed. Then remove the "bulb" access panel behind the projector, flip the lever, then re-install.
    For the A4/B6 they use the same physical light assemblies on Xenons and Halogen set-ups - although Bi-Xenons would be a A4/B7 option I believe and were not available on the B6?
    Might be able to post a picture of the RHD/LHD lever tomorrow.
  6. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    HELLO!!! What's the code-change required?
  7. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    or just go and blind all the French and Germans and save yourself the hassle! :whistle2:
  8. chrisash32
    chrisash32 Member
    573
    Hmmm.. it would seem that they do that to us quite often...
  9. Turkster
    2,811
    54
    yes now your on the money, but in saying that 2 wrongs don't make a right :whip: i drove my BMW E36 coupe M3 all the way to Turkey and back without doing anything to the lights!
  10. h5djr
    9,459
    1,769
    Yes of course. My earlier A3s had the small lever to change the halogen lights. Some of the later ones had no lever and I had to use black patches on the headlights or on headlight protectors. But these are not recommended for Xenons and the later type of headlights have no pattern on the headlight glass to indicate where the patches should be fixed.
    My later A3s have all had Bi-Xenon headlights are these are changed by a recode with VCDS. The method and code changed are described (by me) in this post http://www.audi-sport.net/vb/showthread.php?t=33492&page=2
    It's post no 6 you will require. This is for the current A3 but I'm sure it will be very similar for the A4.
    As far as not bothering to do anything at all, a friend of mine was stopped by the police in Germany for speeding on a restricted area of Autobahn and they checked over his car and found he had no method of blanking out the kerb light in his headlights so they issued an on-the-spot fine for both the speeding and the headlights. It is also not unknown for the French Police to check cars before they will let them leave the port of terminal.
  11. Turkster
    2,811
    54
    Take note lads, this is a confirmed bit of truth, Also i may like to add that the police are looking Hi-Viz Vests in your car, 1 for every human in the car, so a trip to £Land could save you a load of fines later should you wish to pop over and visit our mates on the other side, :o.k:
  12. defsix
    defsix Member
    181
    So as well as adjusting lights, carrying spare bulbs and luminous vests, is there anything else ?
  13. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Warning Triangle in France, and you need to have a GB sticker if you number plate doesn't already have one.
  14. quattrojames
    14,062
    583
    Don't get caught with a radar detector, the Gendarmes will not be impressed :angrymod:
  15. BahnStormer77
    2,773
    60
    Gendarmes will issue a €1500 fine for just having a radar / laser / GPS camera detector in the car, let alone plugged in and working!
    Aside from the obvious "GB" and headlight conversions, I believe the key things are:
    Germany - HV vests and TWO triangles - I think you have to place one 100metres from your car and one near the back of the car.
    France - full set of spare bulbs (I think there is an exception for Xenons though) - but please check for yourselves!!!
    Spain - insurance docs incl EU green-card, otherwise they impound your car even for minor offences until you can prove insurance.
  16. Woorlord
    951
    17
    All you need for continental motoring AA pdf Link.
    Thought a First Aid kit was required but not compulsory in France.
  17. BahnStormer77
    2,773
    60
    WOW - they really don't like Radar detectors in Europe!! They would really hate me (laser, radar and GPS)....
  18. h5djr
    9,459
    1,769
  19. h5djr
    9,459
    1,769
    If you are visiting Germany, then the warning triangle is not compulsory but strongly advised and only one is required not two. Again the wording from the AA reads...
    It is not compulsory for visiting UK motorists to carry a warning triangle, but they are strongly advised to do so, as all drivers must signal their vehicle in case of breakdown, and it is a compulsory requirement for residents.
    Also for Germany the follow applies, again from the AA website...
    It is recommended that visitors equip their vehicle with a first-aid kit and set of replacement bulbs.
    Lights:
    [FONT=Verdana,Verdana][FONT=Verdana,Verdana]It is recommended to use dipped headlights at all times. It is compulsory during daylight hours if fog, snow or rain restrict visibility. [/FONT][/FONT]
    [FONT=Verdana,Verdana][FONT=Verdana,Verdana]Driving with sidelights (parking lights) alone is not allowed. Vehicles must have their lights on in tunnels.[/FONT][/FONT]
    A GPS based navigation system which has maps indicating the location of fixed speed cameras must have the ‘fixed speed camera PoI (Points of Interest)’ function deactivated. The use of radar detectors is prohibited.
  20. BahnStormer77
    2,773
    60
    I stand corrected on the triangles - that was a few years ago and I already had a triangle in the car (E30), plus one in an emergency kit, so I wasn't about to question it...
    Only person I know who was fined got caught on a booze cruise with a dead brake light bulb... Gendarmes pulled him over to get that changed (and he had spares), but then he spotted that he had a Neo Snooper S6 (GPS camera locator + laser detector) - it was in the boot and not being used, so he didn't even bother hiding it, but they threw the book at him.
  21. Turkster
    2,811
    54
    also do not have any fuel in a fuel can in the boot,
  22. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Unfortunately not all B6's have the lever. I had 2 B6 S4's - one had the lever and one didn't. So I could move the lever on one, but had to pay an Audi dealer £100 to adjust them before I went on holiday AND £100 to adjust them back again.
    Adaptive lights (not a B6 option AFAIK) can be set into "Tourist" mode using VCDS (VAG-COM) which makes them dip straight and hence suitable for the UK and Europe.
    Not true of GPS systems - they do not "detect" the camera and are 100% legal in France. I've been to France at least once a year for the last 5 years with my GPS in full view on the windscreen.
    The AA website has a very good downloadable PDF document listing what is compulsory and advised for most countries in Europe - well worth downloading. Don't forget the reflective jackets that are compulsory for ALL occupants in France...
  23. defsix
    defsix Member
    181
    So does anyone have pictures of what i should be looking for ? I can't check because it hasn't stopped raining since i first posted this...
  24. Woorlord
    951
    17
    Pictures as promised of LHD/RHD adjustment lever......
    If you look into the Projector you will see the metal light beam collimator changes with the lever position.
    I've taken these pictures on a "broken" headlight assembly I have in my garage - I am assuming UP=RHD and DOWN=LHD based on how I found this headlight.
  25. chrisash32
    chrisash32 Member
    573
    is this easy to adjust? no clips etc etc before you can move that leaver?
  26. Woorlord
    951
    17
    Remove the rear plastic cover behind the projector and stick your finger in and flip - that's it - no screws or clips.
    The sprung lever keeps it in the relevant up/down position.
  27. chrisash32
    chrisash32 Member
    573
    dragging up an old post here... but how the hell do you get this cover off without removing the headlight?
  28. simon.m
    simon.m Active Member
    2,747
    i dont think you can take it off with out taking the headlight out mate but then that only takes 5 mins to do :icon_thumright:
    my girlfriend is from czech republic and have been there a few times there law states you need one triangle one bulb kit
    one luminous vests and a first aid kit all are a must. as for the lights if its as easy as to changes as above then id change them to be safe all though as said
    in some of the othere posts they dont bother when they come here but then are ploice dont stop them and give them fines so thats are bad.
