Driveshaft/CV Removal
jaylake21 Jul 8, 2012
  1. jaylake21
    jaylake21 New Member
    25
  2. S3SYD
    S3SYD Member
    156
    You need a multi point socket and get someone to put the footbrake on while you undo it with a big bar
    What should of done is undone it when the wheel on the car and on the floor
  3. aragorn
    17,889
    689
    Put the wheel back on without the centre cap, and put the car back on the ground with the handbrake firmly applied, before trying to undo that nut.
    you'll need a BIG breaker bar, and a suitable socket. I use a 2ft bar with a length of scaffolding tube over the end.
  4. jaylake21
    25
    Do you know what size socket i need tried a few 32mm.
  5. b719
    b719 New Member VCDS Map User
    you need a 30mm 12 sided socket
  6. jaylake21
    25
    Thank you - I have know been able to get if off.
