Drivers Window Regulator Broken
fisheggs Jul 11, 2013
  1. fisheggs
    fisheggs New Member
    So putting my window up today and PING. Regulator has broken. 2003 B6 Avant
    Does anyone know if VAG do a repair kit for these and how much? Had a look on the bay but quality from pics looks a bit ropey unless anyone has fitted one they'd recommend?
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    125
    Buy the complete kit for 85 from TPS.
  3. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    yep as above
    or go breakers yard
  4. pauldazzle
    pauldazzle Well-Known Member
    1,115
    79
    Had mine go a few months ago, & repair kit from TPS was about £88 IIRC. Quite an operation to fit though took me a good hour and a half.
  5. Steffgj
    Steffgj Member
    99
    Don't buy a repair kit off the bay! My regulator went back in the winter, bought a repair kit on eBay and it worked for about 3 minutes.
    Still haven't got around to fixing it but will definitely be replacing the whole thing with a genuine item when I do.
  6. pauldazzle
    1,115
    79
    Buy cheap, buy twice.
  7. da4
    da4 New Member
    20
    Got the same problem.What brand is oem in there and what brand should i buy then?
  8. Ian2012
    Ian2012 Active Member
    473
    29
    Buy the audi part it's not that bad a job to fit, you will also need to buy the plastic clips that hold the door card on as they break easily when you pop the card off the door.
  9. krisavant
    krisavant Active Member
    449
    59
  10. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    261
    That's a great guid, hopefully I'll never need it, but going by the two mk4 based cars I've had I will.
