Drivers window opened on its own
Chriscooke Nov 20, 2013
  1. Chriscooke
    Chriscooke Clueless!
    501
    24
    I woke up this morning to find my drivers window open and the seat soaking wet! This has happened before with the same window. I've heard that vag csrs sometimes have an issue with this. Anything I can check/do to stop this happening again?
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Get it scanned to see where/what fault is would be best option.
  3. Chriscooke
    501
    24
    I have an eBay cable. Would this be up to the job?
  4. aragorn
    18,293
    802
    TBH, its usually driver error.
    I've done it myself when getting out the car accidentally clipping the window switch. In my case it was on the passenger side, and i only noticed it because i had a passenger getting out at the same time who said "WTF?" and i realised i'd mashed the button when opening the door.
    Theres no magical fault that can cuase it, and theres no ECU or fault codes to scan.
    The window motors are only powered upto the point where you close the drivers door, so they cant magically power themselves up and wind down after you've closed it and locked the car.
    There are only two ways to open the drivers window, one, with the switch, and two, via the central locking module. However the locking module opens ALL the windows simultaneously, so that rules out any fault there...
  5. Oranoco
    Oranoco Well-Known Member
    3,910
    390
    I've had it twice on mine and can absolutely rule out the squidgy organic bit as being as fault. Locked the car and wiped some bird poo off the window. 2 hours later my Mrs comes in and says window is wide open.
  6. Bradderz_1988
    3,951
    235
    Ive had this before now never looked into it just presumed it was 'driver error' !
  7. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    This happened to me on the drivers and passenger window but only cause I've touched the buttons as I was getting out of the car.
    Never seen it happen any other way.
    I have heard some of the new models doing it but that happened to all windows not just one, so assumed they had skinny hipster jeans on and it pressed the open button on their remote.
    Can't think why it would randomly happen either.
  8. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    this happened to me, drivers window open over night with it pissing down outside
    but thought it was me that left it open which i was 99.99% sure i didnt.
    intresting!!!
  9. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    213
    Yay - I have inadvertently knocked the switch on mine .... good thing I live in a nice neighborhood !
  10. Smeds
    Smeds Active Member
    311
    35
    This used to happen on my MK1 TT and has happened a couple of times on the A3, really worrying.
