Drivers Side Window - Not Going Down With The One Touch
silversurfer Jan 14, 2010
  1. silversurfer
    silversurfer Member
    223
    Hi,
    I've done a search but couldn't find much on this, basically all my windows work fine, apart from the drivers side, which now doesn't go down with the one touch. (But goes closes fine with one touch and normal pressing the button for up and down)
    Any help would be great.
    Neil
  2. Kostas
    Kostas Member
    104
    hold down the button till window goes all the way down and then back up again it should reset iit
  3. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    Mine does the same thing. I think is a problem with the switch since it works fine when closing the window. I've already tried the procedure indicated by Kostas but with no result.
  4. quattrojames
    14,050
    578
    Mine does too, I'll try the 'right down' proceedure tomorrow, but I won't hold out much hope ...
  5. Kostas
    Kostas Member
    104
    don't forget ''right up'' straight away
  6. T0m
    T0m Active Member
    516
    26
    Or when the window is closed, simply pull the switch as if you were going to close it again and that should then reset it...
  7. markyzs180
    markyzs180 Member
    543
    straight down then straight back up holding the button all the way both ways
  8. Kostas
    Kostas Member
    104
    spot on that ended my problem
  9. silversurfer
    silversurfer Member
    223
    Okay, I'll give that a go in the morning. Thanks
  10. Johnny Bravo
    898
    70
    Ignition "ON" I suppose. Right?
  11. silversurfer
    silversurfer Member
    223
    Worked for me.. Thanks Lads
  12. Ash187
    7,495
    744
    hey guys, sorry to dig up an old thread...
    I have a 2005 A3 Sportback
    I have noticed that my windows are playing up like the above... but its intermittent. until i searched and found this thread the drivers door was not doing the 'one touch down'. now i have done the reset procedure and the drivers window sometimes works on the one touch and sometimes doesnt. Now i have noticed that the rear passenger side window is doing the same but only when i am doing it from the drivers switch. If i open the window from the rear passenger door the one touch works...
    now im thinking is it a problem with the actual switch in the drivers door or is there something else i can do to make it work properly?
    thanks in advance guys
