Hi, I had my car serviced a few week ago and since then it seems to have developed a squeak on the drivers side when turning right. Anybody any idea as to what this can be? Rather annoying to say the least, thanks
Considering the weather of late, arb bush maybe, spray some wd40 into the bush & see if it goes.
Turn wheel to lock so rear of wheel sticks out on relevant side, you can get in between to direct spray into that area, done it myself & squeak went
I sprayed it for a prolonged period given its very tight in there, the sustained pressure may have forced some lube into the bush/arb area, a little spray may not help the issue, it may not even be this at fault, but 1 easy thing to check for sure.
Dry, warm, dusty weather makes bushes squeak more, bit like a woman really lmao.
LMAO I didn't even mean it to be so crude, LMAO priceless indeed, it was in relation to there henpicking lmao, but it reads ****** good for an unintentional POV lmao.
What was that other classic line Sandra, one guys got it in there signature lmao.
Well its ramp time with a lever bar to move some bushes a little.
Just follow the arb through to the center of the car, you eventually come to the bush/brackets.
