drivers side front creaking on pull off
Sham101 May 1, 2013
  1. Sham101
    Sham101 Member
    286
    20
    on pull off drivers side front starts to creak from the wheel area and when comming of a curb drivers side wheel just drops off hard and curb hits the bottom of car the car is a 1999 s3 apy standard with 68000 on clock
  2. Steven.c
    Steven.c Auto-Motive Restored Deatail
    282
    sounds like arb/driveshaft rub to me, are you lowered?
  3. Sham101
    Sham101 Member
    286
    20
    not lowerd standard
  4. Steven.c
    282
    it it from the drivers side when you turn right and drop off a curb? dont know how to explain the noise but its a grinding/rubbing like someone is sliding a wooden chair back on a laminated floor?
  5. Sham101
    Sham101 Member
    286
    20
    yeh
  6. Steven.c
    282
    jack up the drivers side and check the driveshaft. sounds like the anti roll bar is rubbing on the driveshaft, it is thicker on the drivers side.
  7. Sham101
    Sham101 Member
    286
    20
    will do but what about the wheel dropping of hard
  8. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    187
    have you checked your top mounts mate
    chris.
  9. Steven.c
    282
    maybe get some harder suspension? have you checked you front struts for leaks as they could be bottoming out causing the banging and arb hitting. standard suspension shouldnt do that normally i only had problems over 40mm. im now about 80mm lol.
  10. Sham101
    Sham101 Member
    286
    20
    top mounts are fine
  11. Sham101
    Sham101 Member
    286
    20
    ok time to take the **** out now
  12. rhubarb4
    1,754
    187
    Tyre pressure ok
  13. Sham101
    Sham101 Member
    286
    20
    tyre pressure 32 psi all round
  14. Sham101
    Sham101 Member
    286
    20
    noise is still there ​ANY BODY WHO CAN HELP
  15. Sham101
    Sham101 Member
    286
    20
    problem sorted wishbone bolts were loose at the back were they hold on to the sub frame *ucking garage
    had put in a new rack and forgot to tighten them wont be going back there again
    should i name and shame
