drivers side elec window switch removal
Adam-D Feb 6, 2008
  1. Adam-D
    Adam-D Member
    457
    how do i go about this?
    do i have to strip the door card off?
    or is it easy'r than that?
  2. diesel-a4
    diesel-a4 Stoned As Fuk
    162
    mines kinna just pops out if i pry at it with a screwdriver
  3. Adam-D
    Adam-D Member
    457
    the surround. or the switch itself
  4. Broken Byzan
    13,237
    465
    The card needs to co,e off to swap the switch. If you look at the door grab handle you will see a little philips screw, take that out,remover the rtim peice.Behind that are 2 more screws that need to be removed.There are also 2 small screems either side of the window rail that come out.
    Once that is done grab the door card by the handle and pull up.The whole thing will lift up and Voila
  5. billybravo
    billybravo Active Member
    1,045
    im sure u have to remove the door card first mate and they pop out from the back easy ten min job
  6. Adam-D
    Adam-D Member
    457
    ok cool, ill pull it apart and swap it. :)
