Driver's side door will not open from inside!!!
Sunbeam08 Jul 14, 2012
  1. Sunbeam08
    Sunbeam08 New Member
    Please help! The driver's side door to my 2009 A4 will not open today from the inside. I can open it from the outside after crawling out from the passenger door. When I lock/unlock from the remote, the sounds sound normal and things are moving within the door. Except the signal lights inside blink twice when they usually don't when I unlock using the remote. The feel of the door handle from the inside is much less resistance than the other doors, feels like something is not pulling?? Also doesn't matter if I unlock using the remote or the buttons inside the door, door still will not open from inside. Help!!!
  2. hades-
    9,481
    646
    why didnt you put the window down open the door and get out ?
    better than climbing over pass seat to get out
  3. Craig Cull
    Craig Cull Well-Known Member
    2,428
    1,361
    remove the door trim and check the state of the cable. sometimes if there not clicked back into place when the door trim has been put back on, it can just pop out. probably an easy fix mate.
