Drivers footwell wet
s3joe Apr 7, 2012
  1. s3joe
    s3joe Active Member
    574
    87
    I have just been hovering my car an found my footwell was wet under the clutch pedal any ideas please.
  2. Danman1
    Danman1 Thorough noob
    342
    19
    Scuttle panel under window screen leaking. Common I believe. Bead of silicon across it may fix it?
  3. jcs356
    jcs356 Brum brum
    2,734
    70
    Yep, the scuttle panel sealing and I also bet the drain holes in the upper front wing are blocked so you've got a puddle of water sloshing around next to the ECU. VAG group cars have some great design faults!
    Recommend you take the wiper arms off, remove the scuttle completely and then clear out all the detritus from either side and make sure the drain holes run free. I now do this every couple of years on S3 and Cordy as part of routine maintenance.
  4. s3joe
    s3joe Active Member
    574
    87
    Ok I'll have a look at this thanks guys.
  5. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Could be clutch master cylinder leaking.check behind the pedal.
  6. s3joe
    s3joe Active Member
    574
    87
    look behind it for what fluid or water getting in
