Drivers Door Creaking Noise. (Aaaarrrgh!)
Jenno Oct 16, 2013
  1. Jenno
    Jenno New Member
    24
    Having just been without an Audi fore a couple of years, i'm back. And so far, not too impressed.
    The main issue is a constant creaking/rattling noise from the rear of the drivers door.
    Its somewhere between shoulder and ear height and its driving me to despair.
    So far ive tried the following:-
    Removing the door trim and tightening the torx screws inside.
    Covering the rubber door seals and plastic window surround in silicon.
    Driving with the window down.
    All to no avail.
    If you slightly open the door while driving the noise goes away.
    Has anybody else had this issue and for the sake of my sanity, how did you cure it ?
    Jenno
  2. davidn-dmn
    davidn-dmn New Member
    Jenno - try some white lithium grease on the door catch itself...my Tiguan did the same and drove me nuts for a while until I applied the grease and haven't heard anything since. I have an Oz S4 Avant and that was one of the first things I checked but its pretty new anyway but I was concious of it - all the best from downunder :)
  3. NHN
    29,295
    1,701
    Welcome to the site David.
    Also striker plate may need slightly adjusting.
  4. Shadowman
    Shadowman Active Member
    592
    43
    I had a similar thing and it turned out to be the small screw which holds a white plastic part ( I think part of the locking mechanism ) which sits behind the door skin...took the door trim off and the screw was loose so I replaced it with a slightly larger one and that cured it......really screwed up the door from taking it off though, so anyone doing this, be carefull with the plastic lugs which hold the door card on !!!!!
    Trouble is, I can hear all the other rattles now !!!
  5. richlean
    richlean Member
    30
    As NHN said, I recently moved the striker plate in by around 2mm and cured 80% of the problem. Haven't had time to try whether another mm or two will solve the rest. By the way, a normal torx will fit the bolts just about well enough to do the job :-/
  6. NHN
    29,295
    1,701
    My advice is use the correct spline tool, as torx can damage the socket & thus cause you loads of grief, should you need to remove/adjust later on
  7. richlean
    richlean Member
    30
    Where can you buy the correct tool? Must admit it felt wrong with the torx.
  8. NHN
    29,295
    1,701
    Halfords do a very good 7 piece socket set for approx. £25, never failed me & had no cause to buy anyother sizes thus far.
  9. richlean
    richlean Member
    30
  10. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,680
    635
    If your taking the door car off buy replacement plastic clips part number (8E0 868 243) and are around 30p each they always break, and even more so in cold weather.
  11. riggssuzuki
    riggssuzuki Active Member
    496
    57
    MIne creaked and groaned until i had the door seals lubed. Just a thin smear of silicon type grease on the rubers and noise gone.
  12. hollow
    hollow Well-Known Member
    1,403
    162
    now the cold weather is here ,the seat belt rubs against the leather seat and squeaks like hell .
  13. richlean
    richlean Member
    30
    I think I've identified the source of the rest of my creaking noise. It's the cloth-covered bit of trim covering the seat belt slider on the B pillar. It creaks when I go over bigger bumps. What I haven't been able to do is to cure it!
    It comes off very easily by peeling the door seal out of the way and pulling the piece of trim inwards. I gave it some silicone grease on the mountings, but it still isn't silent. Any ideas?
  14. richlean
    richlean Member
    30
    As an update, I actually replaced the above-mentioned bit of trim some time ago, and the creak's still there. So back to square one!
  15. SI-W85
    SI-W85 Well-Known Member
    1,321
    351
    Somebody else started a thread regarding the bit of trim you are talking about I'm sure they cured it so I would have a look for that...
