Drivers door and passenger door dropped
Jules Feb 18, 2013
  1. Jules
    Jules Member
    130
    Hi does anyone know how to adjust the front doors mine have both dropped, the swage line is also out and they are both quite close to the wing at the bottom.
  2. Jules
    Jules Member
    130
    Someone must have had this problem, how did you rectify it?
  3. Alan H
    Alan H Need a V8 or Bi-Turbo.......
    457
    The hinges are welded, so they won't have moved. It's more than likely the striker plate that's moved. You need to adjust this.
  4. Jules
    Jules Member
    130
    And this will bring the door back up into place?
  5. Alan H
    457
    In theory yes. But you need to take it easy when adjusting. Does the door feel like it catching when you open and shut the door?
  6. Jules
    Jules Member
    130
    It doesnt feel like it is catching on anything
  7. Alan H
    457
    Check whether the door drops / raises when you shut it or whether it stays the same. You may not feel the catching due to the seals, but you may see it when opening and closing the door.
    setting a door is very difficult to explain on a forum.....
