Drivers carpet soaked
jamessg1962 Aug 10, 2011
  1. jamessg1962
    jamessg1962 Member
    123
    Haven't used car for a couple of days, A3 TDI 54 reg.Went to use it today and have noticed drivers side carpet soaked.Have had quite a bit rain here recently.
    Car's been parked on driveway which does slope to-wards front but never had issue before.
    Had a look with torch above pedals etc but cant find any wetness. tried looking when it was lashing down still no joy.
    Its definitely not coolant as the level hasn't moved.
    Looked at previous threads about drain holes and water collecting on plastic scuttle beneath windscreen.No water collecting there, But can't see much.Looks like you have to remove wiper arms to get plastic panel off .
    Anybody have similar problem let me know if you found anything conclusive.
    Cheers James
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'd also check the drain holes in the door too.
  3. crunchie
    crunchie Active Member
    880
    77
    I've had the same problem on my last two A3's.
    It had been getting in where the speaker seals onto the door under the door card.
    Removed door card, speaker, cleaned, sealed with silicone grease and bobs your uncle!
  4. jamessg1962
    jamessg1962 Member
    123
    Thanks for replies ,but the car mat is dry ,its the car carpet underneath that soaked .Its just below pedals about 10" in diameter.
    If it was the door would the carpet not be wet by the side of the door.
    Checked under door cant see any moisture or any sign of water Ingres
  5. Khufu
    5,704
    31
    There is a pipe witha join for the washers that goes down the side under the carpet on the drivers side. Perhaps it leaking?
  6. NHN
    29,343
    1,719
    Yeap this sounds like either the heater system has got a problem or the rear washer pipe has split in that area, latter being most likely, try checking rear spray jet for functionality if any water comes through.
  7. jamessg1962
    jamessg1962 Member
    123
    Checked rear washer and it's OK .
    Have had hose pipe out spraying car, placed some some kitchen roll on plastic trim where the carpet meets door.
    Low and behold it's showing signs of wetness.After my initial doubts i think it could be coming down door card as crunchie has explained.
    Looks like the door card will be coming off tomorrow for closer inspection.
    How easy is it to get off ?
  8. NHN
    29,343
    1,719
    Well there is an issue with the water draining point as shown, I did a thread on this & tbh forgot to follow up, which have thought recently about.
    I'd say you need new door top seals, if thats dropping straight down through if the seal isnt allowing it to run down to the mirror plastic & then drops down through there behind the speakers, which then runs out of the bottom of door where there is a drain hole, have a look you'll see.
  9. jamessg1962
    jamessg1962 Member
    123
    Thanks NHN
    How involved is it to get cards off ?
    What do top seals cost and are they easy to replace ?
  10. Khufu
    5,704
    31
  11. jamessg1962
    jamessg1962 Member
    123
    Cheers Khufu.
    Well, better sort some tools out !!!
    "Everything will be OK in the end, if it's not OK, it's not the end.''
  12. jamessg1962
    jamessg1962 Member
    123
    Removed door card today, then removed speaker .It was exactly like crunchie's photo.You can see where the water has been running out at the bottom of speaker.
    The original foam seal just crumbled away as i removed the speaker.
    Have replaced speaker and ran a bead of silicone sealant around where it seals against door. Hopefully this should cure problem.
    While I'm on, I'm going to do passenger side as well.
    Thanks for your help .
  13. NHN
    29,343
    1,719
    Better to test the running of water 1st mate, to see where its heading, then take measures with whatever tools at your disposal, to help direct it properly to the channels its supposed to go, even if that correct path sucks already lol
  14. jamessg1962
    jamessg1962 Member
    123
    It just looks like the water runs down the door skin and out a drain hole in the corner.
    Have made sure drain holes are clear using a cable tie poked down hole.
    Can't see how you can direct it any where else.
    So fingers crossed .
    Haven't tried any water yet as wanted to give silicone a chance to set first.
    One thing i would point out is that i snapped two of the clips,the same one on each door,which is a bit of a coincidence !!
    A quick trip to TPS sorted that out .The clips were slightly different but they did the job.
    Now i have found how easy it is to remove door card might sort out some puddle lights as mentioned in another thread.
    Oh happy days!!.....lol
