driver side electric window problem
swalder
As above,
The driver side window just stopped working all of a sudden no indication that it was failing.
There is still power getting to the unit but it sounds like it is turning and you can hear a grinding noise.
Before i take the door card off does anyone know what it sounds like to get parts ordered up etc.
Cheers guys.
Is it a big job to do.?
Thanks for getting back to me.
Sent from my D5503 using Tapatalk
Northern Ireland.
Near the international airport. Antrim direction
You wouldn't have a how to guide or know of one to weigh up if it's doable!
I followed one from you tube. It was for a saloon and not for a cab like mine but pretty similar.
Basically you unscrew the door panel, then disconnect the wires and remove the door panel.
Drop 3 screws out of the motor and pull it off the regulator. Remove the window, 2 screws. Remove the complete window assembly 4 bolts.fit the new regulator and reverse the steps to refit. If I can find the link I will send it to you.
Cheers buddy
I followed YouTube video aswell
Did mine last week
Make sure you have a T45 torx bit
Took about 1-1 1/2 hours
Very satisfieing doing it yourself and saving garage labour
Bought part from eBay for £25 delivered
Reactions: Rodgeri
Great stuff.
I'll get it ordered and it will give me something to do on my nextday off.
