Driver door not locking
B6Steve Jul 4, 2012
  1. B6Steve
    B6Steve Member
    42
    Hi all.
    Ive been having a few problems with my driver door. I can lock the car with the fob but the drive door doesnt lock and the lights dont flash after locking.
    If I lock the car with the key all locks ok and the lights flash once as they should.
    When I press the button on the inside the car to lock it all the doors bar the driver door and the red light doesnt come on. So i cant lock the driver door from inside at all for security.
    So, the only way for me to lock all the doors at once is with the key from the outside.
    It did it a wee while ago but it seemed to fix itself and now a few months laster its doing it again for some reason.
    Any clues?
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    it will be broken wires in the rubber that runs from the door to the main body of the car
    very common problem and easy repair
  3. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    That or a faulty micro switch in the lock mech which is also a common fault
  4. stu_m
    1,441
    wouldn't that only tell the comfort control module if its just open and closed and not stop it locking?
  5. Mike.M
    2,510
    170
    My GTI door micro switch failed the other month and the car did not lock the drivers door as it could to tell if it was open or closed, which meant the alarm would not activate either.
    Process of elimination I guess.
  6. B6Steve
    B6Steve Member
    42
    Thanks for the info guys, I'l get onto the door rubber first to see thats the problem. Cheers
