Hi,
I need some advice as I am really stuck
I have a X reg Audi A3 1.8T Sport. The car is lowered with coilovers. The anti roll bar rubs on the driver side drive shaft when I turn right. So I installed adjustable drop links to help counteract the rubbing. I have tried adjusting the drop links so the anti roll bar doesn't rub against the drive shaft but it still makes a noise when i turn right. The noise is quite loud and doesn't sound healthy at all!
I have read on here that you can buy anti roll bars that fit under the driveshaft so no rubbing can occur. But I am low on cash and wondering if there is anything cheaper that can be done to solve the problem.
I rang Northampton Motorsport but he said it could be anything as the weight distribution on the suspension may not be equal which may be the reason. I am new to this site and modifying cars so don't know much.
Has this happened to anyone? Or does anyone know how this can be solved?
Thanks in advance
Thanks in advance
