drive select
karlabdool Sep 12, 2013
  1. karlabdool
    karlabdool Member
    161
    19
    hi all,
    Is there anyway to jump from auto to dynamic and dynamic to auto directly?. I usually use the drive select switch and going from auto to dynamic is simple, but to return to auto i have to cycle through the other modes.
    Using the mmi just takes too long and requires too much attention.
    I dont like leaving it on dynamic since the revs are too high, esp when following a slow car for some time.
    When I get a small window for overtaking i need to get everything out of the car and therefore jump to dynamic for the pass.
    It would be nice to have a dedicated 'dynamic mode' button like 'sport button' on bmws.
  2. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,564
    1,170
    Surely if you put your foot down in auto it does the same as dynamic anyway?
  3. karlabdool
    karlabdool Member
    161
    19
    no since in auto the car might be in 6th or 7th when cruising behind the slow car and there will be a delay when i kick down unlike dynamic where it will be high revving in 3rd ready to attack.
    I guess i will have to just drive the car manual...I still think dynamic mode could be a bit more sensible with the high revs.
  4. Flode
    Flode New Member
    9
    Have you tried to slide it into sport mode?
  5. Fragup
    Fragup Member
    462
    185
    If Audi list the drive modes in the order on they are set up on the car, i.e.
    Comfort, Dynamic, Auto, Efficiency and Individual.
    then couldn't you set up Individual mode same as Dynamic, which just means a double press on the drive select button when in Auto would take you to Individual instead of 4 presses to get to Dynamic, which is just that little bit easier when you in a rush to over take.
    just an idea, as haven't got mine to test yet, but if there is not a better way to do could be an easy compromise to sort.
  6. Richyboyp
    Richyboyp Member
    156
    23
    What I do: my car is normally in efficiency mode and so like you the gears are wrong for power. Kick down does work well though if I'm honest. Do if I want to change to dynamic I just pull back on the selector which then puts it in 'sport' I just assume this is dynamic although someone may say otherwise. Once I've overtaken I then pull selector back and it returns to E. now I assume if you are in 'auto' this is what it would return to but not tried as I always run E. other option is push selector to the left and manually change gear, that's also fun.
    Hope this helps
  7. Richyboyp
    Richyboyp Member
    156
    23
    Obviously pulling the selector back is while the car is in D. :)
  8. 97catalunya
    97catalunya Active Member
    546
    161
    43
    I just use the paddles when I want to overtake. Just pop it down a gear or 2 overtake then hold the right hand up paddle for a couple of seconds and it returns to auto ;) or just leave it and after a period of time it will switch back to auto it's self.
  9. TDI-line
    TDI-line Uber Post Whore Team Floret Silver quattro Audi A3 Black Edition TDi
    9,676
    1,619
    This maybe a really stupid question, but is drive select only available on s-tronic models?
  10. Richyboyp
    Richyboyp Member
    156
    23
    Think it's se and above ????
  11. cemerson
    4,564
    1,170
    No, available on everything I think (can't remember about SE though, could just be Sport trim upwards)
  12. cemerson
    4,564
    1,170
    Configurator says Sport upwards, so on everything except SE models
  13. Richyboyp
    Richyboyp Member
    156
    23
    Oops! I was wrong :( sorry
  14. dkpeter
    dkpeter New Member
    A bit easier than using the drive select switch is to assign this functionality to the programmable steering wheel button. This enables you to toggle through the different modes with both hands on the steering wheel. Not exactly what was requested but perhaps a bit easier.
    Fragup likes this.
  15. 97catalunya
    546
    161
    43
    I have done this too, shame it can't be used as a shortcut directly to dynamic mode though.
  16. karlabdool
    karlabdool Member
    161
    19
    This sounds better, how do you go about programming the button?
  17. RossR
    RossR Active Member
    501
    122
    43
    It's under car settings in the MMI.
  18. Richyboyp
    Richyboyp Member
    156
    23
    Was going to suggest the button on the steering wheel but not sure if that button is across the models and I also knew it only toggles through not just selects one driver style
  19. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    Sounds as close to a "push to pass" or "overtake" button as can be expected. Ace!
  20. Daveotto
    Daveotto Well-Known Member Team Floret Silver Gold Supporter Audi S3 S3 Saloon
    2,877
    4,170
    you sort of can if you leave it in automatic the next option in the cycle is dynamic
  21. Tom75
    Tom75 Member
    92
    14
    Yes, thats right if you just pull the selector back it goes into s-mode if you pull back one more time you are in normal mode again. however this will only change the gear selection and acceleration to normal s-mode but it will not change the chassie and also not change the steering etc to dynamic.
    Regards,
    Tom
  22. Fragup
    Fragup Member
    462
    185
    that's a cool feature, didn't realise you could do that. Bonus !
  23. karlabdool
    karlabdool Member
    161
    19
    hi, when you say pull back , do you really mean to the side so as to engage the + - manual shifting in sport mode? or is there actually another notch down when in D that takes you to automatic sport mode?
  24. Tom75
    Tom75 Member
    92
    14
    No, not to the side because then you will be in manual sport mode. In the normal D position just pull it a little back and you will see in the display that the D disappears and a S shows up.
    Regards,
    Tom
  25. constvoid
    constvoid Active Member TFSI Owners Group Team Scuba Audi A3
    123
    29
    Yes, but just to clarify for karlabdool - unlike the separate "S" position on the 8P s-tronic selector, this is just a case of moving the selector backwards and then releasing it. As it's spring-loaded it will return to the "D" position, but the box will be in "S" mode until you do the same again.
  26. Tom75
    Tom75 Member
    92
    14
    exactly
  27. karlabdool
    karlabdool Member
    161
    19
    great this should work fine, better than cycling through the drive modes...but one question, when in auto drive select mode and cruising slowly(50-60 kmph) in D6 or D7, if i go to dynamic the car will downshift to S3. Will this downshift happen when i 'pull back'? or will it remain in the same gear(S6 or S7).
    Will try it today if i get the time.
    thanks tom
  28. Richyboyp
    Richyboyp Member
    156
    23
    It will down shift right away. Same as dynamic. And pretty sure when pulled back again it will revert to what drive select you were in originally. I use this all the time :)
    karlabdool likes this.
  29. 97catalunya
    546
    161
    43
    I have been using "Dynamic" a little more now as the miles are building up.
    I have noticed when I change to dynamic obviously the gearbox will go into sport mode. But after leaving the car then getting back in when I start it up the gearbox is in D not S even though the drive select is in "Dynamic"
    Is this normal, I don't know if its just protecting the engine as it is still cold? If so does it automatically go back into S when warm?
  30. Toadoftoadhall
    Toadoftoadhall Active Member
    299
    80
    On the subject of drive select, what are all the possible settings when programming the individual mode? on an S3 test car last week I did have a quick look but cannot recall all the customisable options. I know that the steering was one, engine sound another (though is that S3 specific?) what about the shift points of the s- tronic ?
  31. cemerson
    4,564
    1,170
    Throttle, ACC, Cornering light (god knows what that does), Steering on mine I think
  32. Toadoftoadhall
    299
    80
    Thanks for that. ACC - you mean the adaptive cruise? What setting options for that - the follow distance?
    From your sig info, looks like yours is Manual.
    Can anyone out there let me know about the s tronic settings and what can be adjusted within Drive Select?
  33. cemerson
    4,564
    1,170
    Yeh, adaptive cruise. Not really played with it much but I assume dynamic will stick more closely to the speed or the car in front, and comfort is a bit more relaxed about it
