Dre's S3 adventure :)
dre_S3 Apr 1, 2012
  1. dre_S3
    dre_S3 Member
    756
    39
    Cheers mate :)
  2. dre_S3
    dre_S3 Member
    756
    39
    Yeah cleaned the inside to got keep on top of it as I found out with my old milltek on my focus if you leave it to long it does not clean well
  3. dancupra225
    dancupra225 Active Member
    667
    25
    please say you didnt use a sponge to clean the car with??
    mircofibre mitt should be used stop damaging the paint further. Have you tried clay bar on your car yet?
  4. dre_S3
    dre_S3 Member
    756
    39
    whats wrong with a sponge people have been using them for years i also have mitt but dont use it all the time,
    i put a clay over it a few months ago still got a smooth finish from using these products
  5. dancupra225
    667
    25
    a sponge is really bad as picks up little bits of dirt and puts onto your car buy a mircofibre mitt to be safe for your paint in the long run
    up to you but look into it
  6. Colly
    Colly Member
    282
    making good progress makes me want to do more with mine just need the funds, keep up the good work
  7. Sam_
    Sam_ Down under
    3,038
    480
    Why would a mitt not pick up the same grit etc that a sponge would? I think that's a little bit anally retentive to be honest :)
  8. Sevv
    Sevv Pushing the limits..
    1,324
    120
    lol Sam i use a microfiber mitt to wash it, its softer, doesnt cause swirl marks that we all hate which ends up scratching the paint, the microfiber mitt wont..however i also use some sort of pan to let the dirt and grim to settle at the bottom of the bucket
  9. Sam_
    Sam_ Down under
    3,038
    480
    Bloody hell. OCD to the max! :/ Just drive the f'er :)
    I bought a microfiber sponge type deal, best of both worlds surely? My neighbours already think I'm a bit weird working on my car most weekends. If I start washing my car with a MJ glove on, they'll think I've lost it...
  10. CMcKenzie
    CMcKenzie It's supposed to do that..
    318
    127
    43
    Sorry for the off topic post, but I've just bought the same tax disc holder, and without some kind of packing, I can't get it to sit in the bottom corner flat. Did you use just the six pads that comes with it, or buy more? Just wondered if you'd be ever so kind to share your secrets ;)
    callum
  11. dre_S3
    dre_S3 Member
    756
    39
    lol i had to move it down and to the right abit for that reason should stay on like that :)
    well been awhile since i have been on got a few more things for my S3 :cool: new plate, quality boost gauge and some well needed spark plugs they were that far gone my car was holding back and running lean checked for leaks thought it maybe that or coil packs as my car has been running **** for weeks :( so after alot of reading thought i would change the spark plugs first and im over the moon car is running better then ever all that time and was only them can enjoy the s3 again :)
  12. dre_S3
    dre_S3 Member
    756
    39
    old plugs:w00t: IMGP0199.jpg
    checking for boost leaks under the inlet mani all seems quite new must of been done before
  13. dre_S3
    dre_S3 Member
    756
    39
    and my new boost gauge with added sticker :)
    :s3addict:dre s3
  14. dre_S3
    dre_S3 Member
    756
    39
    well the problem came back and the car was holding back again so thought i would change the coils and upgraded to the 2.0 s3 coils still the same problem :( so thought i would take the inlet mani out and check for leaks as i had noticed abit of oil from the pipes under the that indicated a boost leak ?
    old coils out
    new bosch 2.0 coils in
    pipes undet the inlet mani
    manifold off going to put an oil catch can and get rid of all these dam pipes
    going to change these 2 to
    had a little clean of the oil that builded up over the time of the leak and cleand and put the bottom pipe back
  15. dre_S3
    dre_S3 Member
    756
    39
    took of my throttle bodie and gave it a good clean
    cleaned the inlet manifold
    waiting on my utlrasonic cleaner to do my injectors and going to change the inlet gasket to so this one is off
    also broke my dipstick holder so waiting for a few bits so i can get the car on the road and hopefully sort the holding back problem
    dre:s3addict:
  16. Westy
    Westy Well-Known Member
    17,443
    1,105
    It's a nice cleansing to rip out as much old rubber hose as possible and replace it with fresh new silicone. Usually solves a fair few issues a the same time so good luck.
  17. dre_S3
    dre_S3 Member
    756
    39
    Yeah cheers mate got quite a lot of stuff including a few hose on order will hopefully have it all together by Friday
  18. dre_S3
    dre_S3 Member
    756
    39
    got a bit done today still waiting on some deliverys though :( so hopefully i can finish this off tomo
    fitted my catch can and sorted out some other bits to ready for when my hoses come big thanks to Westy for his how to do thread :arco:
    my 42 Draft Stealth Oil Catch Can
    [​IMG][h=1][/h]oil stick some bungs and a new black coolant cap
    kept this bit that connets to the intake mani and capped it off
    put a new hose on that goes to the n249
    took off my puck valve and bunged off the tip
  19. dre_S3
    dre_S3 Member
    756
    39
    next was to make some room for my catch can
    also moved my alarm
    made a bracket for the can
    just enough room after putting the strut brace on
    thats if for now will update tomo :) will hopefully have it finished if everthing comes
    dre :s3addict:
  20. Westy
    17,443
    1,105
    I'm guessing you have an after market alarm if it's under the bonnet!
    How come you haven't binned the N249 valve yet?
  21. dre_S3
    dre_S3 Member
    756
    39
    Yeah it's an aftermarket but they never bothered to disconect the Audi alarm though so if I press the Audi key the stock alarm activates if I press my alarm fob only the viper alarm activates
    Not sure why I have not mate read so many mixed reviews not sure I should
    Tony gold likes this.
  22. Westy
    17,443
    1,105
    I've never need a mixed review on here mate! Everyone goes wild for it. Trust me you will like it. Makes the throttle so much more responsive.
  23. dre_S3
    dre_S3 Member
    756
    39
    Ok mate I will give it a go just need to sort this problem out with the holding back first hopefully all this that I'm doing solves my issue will know tomorrow :huh:
  24. Westy
    17,443
    1,105
    You never know, it could be N249 pipe work related ;)
  25. dre_S3
    dre_S3 Member
    756
    39
    nah mate this is the problem by the looks of things
    hopefully get to the end of this now big thanks to s3Dave for saying it could be the harness:arco:
  26. Westy
    17,443
    1,105
    Ahhh the old coil pack wiring! Hopefully that's the issue bud.
  27. dre_S3
    dre_S3 Member
    756
    39
    got alot more done today even though it did not solve my problem atleast it looks like we have found it :)
    oil can all hooked up and a few more hoses changed over to
    my new coolant cap
    got my ultrasonic cleaner to so gave all my bits a cleaned works very well
    done it twice then out in the sun to dry
    my new hoses
    DV and n75 hoses
    brake servo hose
  28. dre_S3
    dre_S3 Member
    756
    39
    fitted new oil stick
  29. dre_S3
    dre_S3 Member
    756
    39
    new pipe from under the inlet mani
  30. dre_S3
    dre_S3 Member
    756
    39
    joining up all my catch tank hoses
  31. dre_S3
    dre_S3 Member
    756
    39
    oil catch can all fitted
  32. chaz20vt
    chaz20vt Member
    428
    21
    Looks real nice that does what catch can are you using
  33. Sam_
    Sam_ Down under
    3,038
    480
    I really should check my coilpack wiring. My car's been acting weird recently...
    Looking good mate. No check valve in the servo hose ?
  34. dre_S3
    dre_S3 Member
    756
    39
    Cheers it's a 42 Draft Stealth Oil Catch Can seems good quality
  35. Colly
    Colly Member
    282
    Looking good I want to put a catch can on mine but it looks like a fair bit of work . I think I'll do the n249 bypass this weekend.
  36. chaz20vt
    chaz20vt Member
    428
    21
    Just had a look bit pricey though
  37. dre_S3
    dre_S3 Member
    756
    39
    Yeah really think this wiring is my issue got a harness on order
    No check valve needed mate as Tuffty pointed out there's one at the top left of the engine bay behind the boost pipe
  38. dre_S3
    dre_S3 Member
    756
    39
    mate it looks harder then it is really is **** easy
  39. dre_S3
    dre_S3 Member
    756
    39
    fitted a new clutch pedal last night and today :keule:got everything together last night and the cluch pedal was very wobblely then relised there is 2 little washers on the old pedal so the thing had to come off and do it all again this morning was not happy
    my new pedal all welded this one should not snap as im not doing it again even if you paid me lol
    these are the f**kers i left off
    all on now :yahoo:
  40. Westy
    17,443
    1,105
    I've done that before too mate lol. You learn from your mistakes.
