Dreading the coolant verdict, Your thoughts?
Mick a3 Jul 31, 2010
  1. Mick a3
    Mick a3 Mellow Yellow
    266
    So my cars been screaming at me for coolant for the last month or so now and ive been topping up every 5 or 6 days. Filled the coolant up and went a 20 minute motorway drive to come back and find it was empty again. Theres no leaks, pressure test showed nothing at all but the water is still going somewhere! Coolant has started to change to a foggy brown colour over the last few days and my temp gauge is bone idle and wont move unless i'm on the motorway at this point all warnings go away.
    As for white smoke i noticed some while reversing outside my home the other day and it wasnt terribly bad but it did catch my eye, There's no smell of oil in the coolant and no signs of the oil being gunky or white.
    Cars in the garage just now and only showed up 1 fault "Coolant sensor fault" so they have sourced the new part and fitting as I type, But surely this wouldn't cause the coolant to rapidly dissapear?
    Been online reading and faults could be as follows
    Cracked Head
    Water pump ( I wasn't aware your supposed to change the water pump when changing the timing belt)
    Thermostat
    Radiator rusting in one of the corners.
    Im leaning towards the head being cracked and absolutely dreading the phone call saying its going to cost a fortune!
    Mick
  2. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,228
    320
    there's been a few threads on this problem and it sounds like a cracked head 2 me
  3. Matt
    Matt Active Member
    1,404
    Cracked head. Had mine done under warranty.
  4. FranA3
    7,228
    320
    yeah thats what i thought it sounded like 2
  5. Mick a3
    266
    Got it back and and the new sensor seems to have cleared the errors,temp guage and juddery startup, Also had a small service(oil and filters). The mechanic took it a 15 minute blast up the dual carriageway and the coolant's still there.
    Time well tell to see if the error appears back, according to audi its a very common fault for that sensor to go. Fingers crossed my coolant doesn't budge!
  6. FranA3
    7,228
    320
    happy days then mate fingers crossed its all sorted then i bet that was alot cheaper than a new head lol
  7. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    Hope its sorted! If it does return, I'd also agree porous head! Bad news if it is......(what engines in it by the way??)
  8. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    None of that will stop the engine loosing coolent. If you need a head pm me as i have a few secondhand ones left in stock at the moment.
  9. Mick a3
    266
    thanks mate i'l keep that noted encase it goes tits up!
    Its a 2.0 fsi, done just short of 200 miles tonight all seems fine so far, Apart from i managed to clobber the biggest pavement this side of Scotland and dent my sill!
  10. devonmikeyboy
    1,245
    Sorry i thought you had a diesel PD140 as they often have head issues. I only deal with diesel PD140 engine parts.
