Draining coolant and refilling, How to?
willh92 Jan 23, 2014
  1. willh92
    willh92 Active Member TFSI Owners Group Silver Supporter Audi S1 Team Brilliant Black
    367
    59
    I'm looking to drain the coolant out of my '99 S3.
    How would I go about doing so, anyone got a step by step? Likewise for refilling?
    or what is the best point to drain it out from?
    cheers
    will
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    There is a drain valve at the bottom of the radiator, fill slowly with heaters on hot and full squeezing bottom rad pipes as you go..
  3. <tuffty/>
    21,157
    3,835
  4. willh92
    367
    59
    Cheers tuffty, good guide there.
    How do you bleed the system?
    Also, does refilling the system from the header tank fill the radiators up if the drain point is on the rad? Cos on some things I've had to fill the rad first then from the tank.
  5. Wallm0nkey
    Wallm0nkey Member
    225
    I had no problem refilling from the header tank just kept the heaters on and squeezing the pipes.
  6. <tuffty/>
    21,157
    3,835
    When doing rods and head swaps etc on 20v's I normally drain from the rad tap then drain out the back of the block...
    Use new OE banjo sealing washers for the turbo line once drained and then fill through the expansion bottle...
    Once the level in the tank has reached the point its not draining down I normally leave the engine idling for a while with the expansion tank cap removed topping up as required......
    Be aware the coolant level will rise a bit as the temp increases but you need to get to a point that the stat opens to ensure the system is filling
  7. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Is that in the stickies, Paul? As might be an idea to add if not :)
  8. Andrew@A.L.D
    3,877
    617
    this is what he means
    http://www.audi-sport.net/vb/a3-s3-...y-check-when-its-cold-warning-skin-burns.html
  9. <tuffty/>
    21,157
    3,835
    Good point... this is what happens if you are not 'paying attention' (shall we say :))
    Never had an issue like this running the engine with the cap off BUT.... you can't leave it... I always keep an eye on it and NEVER undo a cap on a hot engine... let the engine cool down a bit first then slowly undo the cap to release the pressure whilst keeping an eye on the level in the expansion tank... if it rises as you undo then tighten back a turn or two and move away....
    Its a bit like undo a pop bottle thats been shaken only coolant WILL strip your skin... (as demonstrated by the lovely Andrew)...
    Not a good place to be (hope its healing ok mate)
  10. Andrew@A.L.D
    3,877
    617
    Yes unexpected air lock in the coolant system and rushing was my fault that i was injured
  11. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    196
    This is my how too!
    LEGEN..............Wait for it ..........DARY
    Sean
