Drain point for air con condense
jetskijimmy Jan 28, 2012
  1. jetskijimmy
    jetskijimmy QUATTRO
    77
    Anybody now how to check if drain point for air con condense is blocked ? As my windows are steaming up
    James
  2. sewell10
    sewell10 Member
    236
    the drain point is underneath is your ac working q
  3. kite
    kite Member VCDS Map User
    676
    Have the HVAC system scanned for faults. You could have a stuck flap motor.
  4. jetskijimmy
    jetskijimmy QUATTRO
    77
    Cheers for the info - I'll get it checked out
    I have noticed a sound like one the flaps trying to open ?
  5. gary3306
    gary3306 Active Member VCDS Map User
    989
    40
    You may also have a very dirty or damp pollen filter because it is in the plenum chamber. If the drains are blocked, it can give these symptoms
  6. jetskijimmy
    jetskijimmy QUATTRO
    77
    I've changed the pollen filter, and let off a gas to clear the smell from air con, when I turn the air con on the windows steam up but then clear, the windows will steam up again when the engine is turned off.
