HiThe sycromesh on the odd gearshaft fails as they are defective
I have both connectors dq250 and dq500. the purple black wire is on pin 2 dq500 connector,will my 2014 gearbox work or it has a module protection code?
Is it hard to code the box to my manual Audi A3It should work. Just stick to the wiring i posted. Isolate the other wires from dq250. Worked for me at 1st attempt
I think I got if done now just needs coding for it to work will let you know how I get onYou need the wiring diagram from your car and the one from tiguan or q3, do some wiring and it should work.
It's much easier if the car is already DSG because the wires are already there, just swap connectors and you are done.
Can gateway needs coding to be told if it has a dsg gearbox instead of a manual gearboxDoesnt need any coding. Gets everything from can
HiCan gateway needs coding to be told if it has a dsg gearbox instead of a manual gearbox
HiDoesnt need any coding. Gets everything from can
Hi Guys.
Iam just about to do a DQ500 swap to my mk6 gti Dq250.
I think i got most parts - a DQ500 NEZ Box from a Tiguan 2.0L TSI , fron axlesm connectorm etc.
Can somone help out with what do i need to do, rguarding the electrics part of things ?
The pinouts on the DQ500 Conector, VS the DQ250 , and what changes do i need to make in VAG COM to make this work ?
Thanks,
Dany.
I think my gearbox is starting to slip on hard pull at 4300-4400rpm and then it goes ok till limiter.
Here is a video. Remember this is 2.0 TDI engine, much slower than RS3.
I'm leaning heavily towards a 2.5L big turbo engine swap, so putting a DQ500 would allow me to handle the extra torque.For a gti i wouldnt do the swap as its good for 550nm without issues.
I used everything from the tiguan-driveshafts included.
Verify part numbers from a3 and rs3, if they match buy the cheaper one.
Anybody has a DAMOS for the DQ500 gearbox?
grainqey referred to a RS3 support bracket.
I don't know if it's the top transmission mount or some other bracket I'm not aware of.
Sent from my SM-G950W using Tapatalk
I ended up butchering and welding two together - think one was from a tdi tiguan for the transfer box side of it.I'm a bit late but for the sake of completeness, the RS3 8P bracket is 0A6409905B. I'm trying to work out which bracket to use on my 06A 1.8T. I have 0A6409905H but I'm not sure it's suitable. The "B" bracket is pretty pricey. What did you guys use on yours?
Hello everyone,
This thread is very interesting and will most likely help others in the future. I think there's enough info in here to start a swap. And as I understand it, after the swap, the car should start and drive atleast.
I own a quite unique car, a Skoda Superb MQB with almost 500bhp. The car runs well but I love the DQ500 as I had it in my TT RS back in the days.
Since my car is an MQB, it might be somewhat different from the cars in this thread. I'm only scratching the surface as it is now, but my spontanious thoughts is that a DQ500 from the new RS3 (MQB) should basically be plug and play, might have to swap out the CAN-GATEWAY.
Any thoughts of all this from you guys? My CAN-GATEWAY is: 5Q0907530AJ it also says 5q0907530M
TC, Great work, this was awesome to read!
Any of the dq500's should be plug and play as they all run on UDS rather than CAN, the problem with the MQB platform cars is that they communicate correctly between the car and the gearbox which will run you into component protection which means a trip to VW or AUDI, followed by them trying to fob you off or want lots of money unless you drop on a friendly dealer (I can't remember if it's just within the immobiliser) there have been people that have swapped from manual to dq250 on the MQB platform on various Facebook groups and ran into component protection so might give you a better answer on there (I've personally never had a problem with it but I didn't have an MQB)
HTH
