  1. Bradderz_1988
    3,946
    235
    Well i no it doesnt apply to B5's but thought id pass it on as we just had a memo at work regarding DPF removals !!
    VOSA are now incorporating them into the MOT test as of febuary, to check wether its been removed due to emissions and its actually 'illegal' so if you have removed it, then you will need to have it refitted for your next mot, unless you no a generous tester that is lol !!
  2. aragorn
    18,135
    764
    its only a visual test though right?
    So an installed DPF with the insides smashed out is likely fine...
  3. Bradderz_1988
    3,946
    235
    Yes correct aslong as its 'visible' and all the associated pipes sensors are there then it will pass !!
