DPF Removal pros & cons
MarkyM Apr 4, 2013
  1. MarkyM
    MarkyM Member
    80
    My 07 3.0 TDi's been remapped already.
    Looked in the boot and according to the label it DOES have a DPF, no problems whatsoever so far.
    So questions are:
    1) Will I need to get it remapped again once DPF is removed
    2) What are the disadvantages?
    3) Advantages?
    4) Has anyone had it done & what did you pay?
    And finally I do appreciate the saying... 'if it ain't broke...:unsure:
  2. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,255
    586
    1. Yes you will
    2. Possibility of a little smoke now and then, how much depends on the map.
    3. Increased Reliability, Power, Economy.
    4. Prices vary depending on competency of the company. We are in Manchester and a specialist and charge £500 drive in drive out for everything, guaranteed with after sales care.
    Thanks, Rick
  3. MarkyM
    MarkyM Member
    80
    Thanks Rick
    1) I'll probably not bother knowing that
    2) Good to know
    3) Is an Alientech eco remap that currently has seen me do 55MPG+ and 950 miles on a tank
    4) Anything from anyone else?
  4. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    you sure its got one, or just got dpf prep
  5. MarkyM
    MarkyM Member
    80
    Dunno, read a post where NO DPF is designated by a certain code on a sticker inside the boot, mine doesn't hve that designation so am assuming so.:confused:
  6. fishyfish
    fishyfish Member
    126
    40
    Mine is an 07 as well, with code 7GN (DPF preparation) on the spare wheel well sticker, and it does not have a DPF fitted... its just a little secondary cat near the passenger foot well (which I am contemplating having cut out).
    For what its worth, I don't get any smoke (with a "power oriented" remap) unless I absolutely stomp on it. I would bet that with a "economy" map, there would be 3/5ths of sod-all smoke even at load, as the fuelling would be dialled way back.
  7. MarkyM
    MarkyM Member
    80
    Mine DOESN'T have 7GN on the boot sticker, which means it has a DPF.
  8. ZYX
    ZYX New Member
    22
    Jasus 55mpg !! That's good goin Man !!
    An Eco Re-Map - Has it changed the Power delivery / characteristics of the Engine ? Has she still got the Grunt ?
  9. MarkyM
    MarkyM Member
    80
    ZYX
    Not that I've noticed, maybe a little hunting on the revs just below 2k
    As to the grunt both of my previous cars were a little quicker (LPG'd dual remapped XK8 and supercharged MX5 18psi).
    On the run that returned the 55MPG I was stopped by Mr Plod for doing XXX MPH that rsulted in my first 6 points in 30yrs of driving :ohmy:
    So fitted a performance exhaust so I can 'hear my speed' better...but the cars so darned well insulated only those outside can appreciate it :huh:
    Am wondering if DPF removal/Auto-RX/Terraclean can see me hit close to 60MPG :salute:
  10. fishyfish
    fishyfish Member
    126
    40
    I would wager you will see a healthy increase in MPG if you do get it removed, as they really do bung up the airflow.
  11. MarkyM
    MarkyM Member
    80
    Yep most probs the same as a Cat on a petrol car, removed them from my XK8 (not needed as LPG) and saw a 4MPG increase straight away...more power too :)
