DPF problems
smudge_don Apr 15, 2010
  1. smudge_don
    smudge_don Active Member
    2,944
    My car has recently been losing a bit of power and idling at 1,000rpm instead of 800
    I've been told by Audi that this is due to the DPF getting full and the engine needing to work more to burn off the **** that gets caught in it
    Stupid question, but if i get a DPF delete with my custom exhaust system, will this problem be erradicated?
  2. robby
    robby Active Member
    579
    69
    Yep - PF does away with the filter - lots of people doing it on the Seat forums
    I read the filter gets blocked with a lot of short journeys and you should do a longer run every now and then with revs at 2000rpm for several minutes (think that was on the Seat forum?)
  3. dantdi
    dantdi ...
    521
    How many miles has your a3 done smudge_don? Starting to worry about mine now, Not that ive had any problems yet touch wood.
  4. Mikey
    Mikey Member
    885
    afaik I dont think you can just delete your DPF, otherwise you will get all sorts of error codes on dash etc etc? JBS do a dpf delete pipe and custom code software to sort this out, along with appx 220bhp!!
  5. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
  6. smudge_don
    2,944
    Ye that's what i was told, apparently the older DPF models allow it to get full and then it tried to burn it off, whereas the new ones burn off the **** as it goes along so you don't get this problem
    Just shy of 30k now mate, it's not really a problem, it's more of a characteristic of the car apparently
    Contradicted yaself right there.....
    Plus, did you not get that i was going to get a DPF from my 1st post?
  7. Mikey
    Mikey Member
    885
    what I meant was you cant just delete your DPF and thats that, you will get error codes, unless you get some sort of software or vagcom (maybe?) to sort that out. DPF has sensors.
    PS- Was only trying to help you, so be careful how you word your replies to people who try to help you in future.
  8. navnayyar
    navnayyar Member
    756
  9. smudge_don
    2,944
    Getting mine done by AMD next month hopefully
  10. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Its threads like this that make me glad I got the 140 :icon_thumright:
    Untill I read to the power gain with the DPF delete........
    Get it done now smudge, your wheels deserve it :)
  11. smudge_don
    2,944
    I deserve it too :laugh:
    Should be running about 230bhp when it's done with the map :hubbahubba:
