dpf light on
jessie123 Jan 2, 2012
  1. jessie123
    jessie123 Member
    90
    [​IMG][​IMG]jessie123: dpf light on<br>hi all happy new year to you all <br>my dpf light came on again but there is no dpf pipe any more &amp; remapped about 6 weeks ago now 203 bph and very good tourqe. put back on vag com no errors found.its a a3 8p 2.0 quattro any help welcome
  2. 347
    347 Active Member VCDS Map User
    362
    59
    even though the dpf has been removed the pressure sensors are still retained in the delete pipe , it could be one of these failed , these normally give a fault code though .
    phone up or take it back to the remappers is probsbly your best bet :cool:
  3. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,051
    755
    As said above, if the pressure sensor is caked then you will need to change that for the light to go off your DIS.
    upside is your not in limp mode..
  4. jrsteeve
    jrsteeve Member
    136
    Yet! I had the DPF light and emissions light on despite the DPF delete, turned out to be a dodgy wire on the pressure sensor.
  5. jessie123
    jessie123 Member
    90
    is that the exauhast pressure sensor on the back of the bulkhead if so i changed that 6 weeks ago before the dpf delete and remap
  6. jessie123
    jessie123 Member
    90
  7. jrsteeve
    jrsteeve Member
    136
    From memory yes, there's not much else other than the software that can bring on the light now the dpf is gone.
  8. jessie123
    jessie123 Member
    90
    how do i now if i have a dodgy wire . and also there is aflat spot on hard acceleration for a split second
  9. t8ups
    2,051
    755
    if you bought the sensor from Audi take it back to them and if its faulty they will change it for free.
    it is the one at the top of the engine bay.
